Comp #1500 Shaft Mounted Rockers
I'm still putting together my head / cam swap for March. Originally, I was thinking of having the stock rockers rebuilt by H.S. (about $260, I think) and was thinking of running the billet steel rocker stands from Lingenfelter (again $260) to help support the rocker stand area of the Patriot CNC'd 243's I've yet to assemble with hollow stems, 918's & Ti Retainers...
Then I got to thinking that for the price ($520+), for a little more, I could go with the Comp 1500's and get a roller tip and stronger valvetrain?
If anybody has experience / input on this idea, I'd appreciate it...
Good Day!
The only way to dial in the valve train is with adjustables.
The oiling system on the 1500 is bitchin.
You have to change the pushrods, and you may have to relieve the pushrod hole in the head for clearance, so the pushrod won't rub.
Anybody else?
Just couldn't Dremel out enough stuff to get them to clear.
Pushrod length is looking like 7.100" (I am still adjusting).
Replaced all the springs (Comp duals) and retainers.
im no expert but I will be going down this path with my build. Solid roller cam and these rockers or the jesels... I’d call comp cams and ask them. They will have all the info as far as where the roller should be on the valve and how to adjust them and torque specs
fyi
“The 20042 rocker set is the same material as any of our other rocker arms, we see well over 1000 lbs open pressure with zero issue. For the lift the biggest obstacle you have to deal with is the valve length and the possibility of a custom stand. That will solely depend on valve length. you are correct that our 20042 set is Comp Cams 1500, we just laser their logo on them add a spring oil hole and ship them out.”
so I guess the comp ones have the spring oil port where as the T&D rockers don’t
