MS4 cam and stock block?
Old Jan 15, 2007 | 06:14 PM
Omega Doom's Avatar
Question MS4 cam and stock block?
I have decided to use the MS4 cam but I was wondering if I go ahead and install it along with the stock heads and intake will this be ok until I get the TFS 215 heads(I really have to save up for those)but I will be installing pacesetters long tube headers,3" true dual exhaust with bullet mufflers,Yank PT 4000 stall,trans go shift kit,tranny cooler,dry nitrous kit, and I have a 02'WS6 T/A that all this going into!
Old Jan 15, 2007 | 10:10 PM
cws T/A's Avatar
Go for it , it will run good cam only with those supporting mods.
Old Jan 15, 2007 | 10:19 PM
brad8266's Avatar
you will be ok, but say bye to your low end power
Old Jan 15, 2007 | 10:22 PM
LS144's Avatar
MS4 is supposed to make descent low end power isnt it?
Old Jan 15, 2007 | 10:27 PM
Mssingkid's Avatar
The MS4 has some pretty good valve events, Low end power won't even be a concern since your going to run a 4K stall... I say go for it!!
Old Jan 15, 2007 | 10:48 PM
brad8266's Avatar
What do you mean when you say it has good valve events? LOL, its like 238 intake duration, that valve closes so damn late you will lose plenty of DCR, which will make you lose low end. Put the specs in a dcr calculator to see what i mean. But with a 4k stall who cares anyway?
Old Jan 15, 2007 | 10:49 PM
brad8266's Avatar
Not really. Intake valve closes way too late for good DCR with a otherwise stock motor.
Old Jan 15, 2007 | 11:30 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most cams like that are going to be robbed of low end. IT will still pull, but not like a 224 does down low. I know that I chose a cam that gives me good power down low....if you consider low 3600rpms.
Old Jan 18, 2007 | 10:14 AM
Omega Doom's Avatar
any more info on this subject would be greatly appreciated?
Old Jan 18, 2007 | 12:11 PM
PREDATOR-Z's Avatar
It has good valve events for the powerband it is designed for. It is by no means optimized for stock SCR, but the power it makes up high is like a screaming gorilla.
Otherwise, there is very very few ways to optimize DCR at 10.1:1 SCR, unless you want a tow cam
FYI, even the stock cam is not optimized for DCR, heck it doesn't even reach 8
Speaking of optimizing, who is gonna put 2.08 valves on a 3.905 bore???
Old Jan 18, 2007 | 12:13 PM
brad8266's Avatar
No doubt it has great events for that powerband, the valve event comment was in respone to me saying to say goodbye to low end power. But like was stated with a 4k stall forget about seeing the low rpm's anyway.
Old Jan 18, 2007 | 12:27 PM
PREDATOR-Z's Avatar
If 300lbs by 3000rpm not good enough, I wonder what the hell you are hauling in the trailer.
Old Jan 18, 2007 | 12:31 PM
brad8266's Avatar
Was it a stock block/head motor or what? That is damn good. If that was cam only then i take back the low end comments.
Old Jan 18, 2007 | 12:33 PM
PREDATOR-Z's Avatar
Yep, cam only + bolt ons 417rwhp/393rwtrq
Old Jan 18, 2007 | 01:25 PM
V6 Bird's Avatar
I see youve moved to the Darkside Omega. Beenfetched here
Im not sure what your goals are but thats not the cam id be using for that car....PM me if you have questions you want answered.
Old Jan 18, 2007 | 07:20 PM
Omega Doom's Avatar
not me bro!
Old Jan 19, 2007 | 09:03 AM
Omega Doom's Avatar
whats your combo?
Old Jan 19, 2007 | 09:54 AM
PREDATOR-Z's Avatar
whats your combo?
370 LME iron with nitrous pistons (2.2cc VRs).
232/234, .595/.598 113+0 degreed
PRC 5.3L stage 2.5, milled .025 (59cc), with race finish and platinum duals.
Bolt ons with a 2 stage dry+ supporting drivetrain
~11.88:1 SCR and 8.68:1 DCR
Old Jan 19, 2007 | 09:55 AM
cws T/A's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/612494-cam-bolt-ons-417rwhp-w-ms4.html
01 M6 MS4, 160 Stat, TR55's, P&P Tb, Lid, K&N, Pacesetters, TSP ORY, Full Exhaust, 25% powerbond pulley, Free Mods
Old Jan 19, 2007 | 01:08 PM
N4cer's Avatar
Most of the posts I've seen from people who actually have the MS4 are saying it's not got the low end that it was marketed and claimed to have. But I'm still highly intrigued by the cam. I can't wait to see LS144's car with that cam in it. Looking at valve events, I think there's a nice LSK lobed custom grind that would be all around slightly better within a usable powerband (<7000 rpm) by looking at the valve events.
