Best Place to buy Main/Rod Bearings?
Like the title says, could you guys give me a web site where i could order some. Also thanks to all the people that helped me decide what main/rod bolts to get. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Katech Rod Bolts for stock rods are the best.
Federal Mogul is in Chapter 11 right now, but makes most main bearings. Clevite makes good rod bearings. You might be able to get Clevite mains?
How much are they? I would say that if you need a "Pro" type rod bolt you shouldn't be using a stock rod in the first place. Go with the ARP rod bolts ($75) and you will be fine.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TimZ28:
<strong>How much are they? I would say that if you need a "Pro" type rod bolt you shouldn't be using a stock rod in the first place. Go with the ARP rod bolts ($75) and you will be fine.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Probably true, but if you are doing bolts the best ones on the market are only $122. 170-190k Tensile $75 ARP vs. 240k Tensile Katech $122.
Katech says the small end of the rod should shatter before the big end ever comes apart with these.
Yeah i got the ARP Rod Bolts for 75 from Pace <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> Im thinking of getting Clevite rod and main Bearings. ABout how much am i looking to spend on these? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
