HARD STARTS
Old 03-24-2002, 07:08 PM
SwEeTWs6's Avatar
Default HARD STARTS
car has trouble starting cranks but wont start then when i try again starts up whats the prob???PLEASE HELP THANKS
Old 03-24-2002, 07:10 PM
BIGBOS's Avatar
Default Re: HARD STARTS
might be the starter
Old 03-24-2002, 07:26 PM
LS1derfull's Avatar
If it cranks but wont start then its not the starter. You could have a bad crank sensor, or weak ground connection somewhere for pcm, also check fuses for IGN, and PCM for corrosion.
Make sure fuel pump is running each time you go to crank motor.
Old 03-24-2002, 11:08 PM
SwEeTWs6's Avatar
how can i check all these to see if thats the problem?
