picking the cam
Old Mar 27, 2002 | 12:11 AM
Air21's Avatar
Default picking the cam
I'm in the market for a Cam. I was looking at a few cams and would like your reccamendation. I will be having my s2 heads milled .40 (11.3:1 or 11.5:1, not sure yet) I also need to know what valve springs (i'm assuming double) and rockers as well. I dont mind shifting around 6800 either. I'm trying to get as close to 10's as i can with my m6, and not have driveabilty issues.
223/223 .588/.588 112
224/224 .281/.281 112 (CC XE-R)
G5
228/228 .585lift 112LSA XE-R
and the Thunder 224 112 lsa cam
Old Mar 27, 2002 | 12:20 AM
VINCE's Avatar
Shorty Director
Default Re: picking the cam
You plan on valve reliefs..?
Old Mar 27, 2002 | 12:32 AM
Air21's Avatar
i'm trying to stay away from any clearance issues. I think the heads are the 5.3's milled .40 for 11.3:1
Old Mar 27, 2002 | 12:35 AM
VINCE's Avatar
Shorty Director
I have the 5.3L heads milled 42 thousandths. You might want to pick the smaller cam. The big ones would be taking a chance.. I have the T1 and I am going to stay with it for now.. I have other issues that I am working out..
Old Mar 27, 2002 | 12:53 AM
TimZ28's Avatar
What valves are you going with?
Old Mar 27, 2002 | 12:56 AM
Air21's Avatar
2.055/1.60 Ferrea valves
Old Mar 27, 2002 | 07:46 AM
Holes02's Avatar
I know of an A4 that dynoed 403rwhp/390rwtq thru and UNLOCKED converter (TP4400) with heads similar to those with a 224/224 .563/.563//112
He was running 11:1 compression.
Old Mar 27, 2002 | 08:19 AM
CHRISPY's Avatar
I would personally run the 228/228 .585lift 112LSA XE-R with a good double spring and lifter. BUT I would clay the heads and check your clearances first.
That cam with LS1edit tuning would ROCK IMO <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Chris
