Comp grinds another cam off spec.
If he's so worried about the cam being off 2 degrees then he better degree it because chances are it will be a few degrees off once he installs it. I love it how the people who have no idea what the hell they are talking about bash the people who actually know what they are talking about.
. We all know this is the real world and nothing and no one is perfect. +2 degrees is beyond the acceptable real world limits and I am glad that he posted these results because now more people will pay for the fancy cam doctoring service. For straters if you want to be **** about grinds and like to do it perfect, you get a cam ground with zero advance and you dial it on dyno with adjustable timing chain trying runs with 2* increaments (advance or retard) and test what gives the best results on you combo.
Even if the cam is ground 100%, which it will never be on mass grindings, sticking it dot-to-dot cannot garantee that it is actualy at said ICL.
The only thing I agree about this whole argument is if you order something a certain way, you should get it that way and no other.
What I would have told Comp is since they messed up, instead of gettingf another cam to send me an adjustable chain FOC so I can dial in my advance. I had a sponsor do exactly that for me a couple of years ago.
I personally wouldn't put the front cover on an engine without degreeing a cylinder on each side of the engine to make sure both banks of lifters bores are in the right place. Another thing that will get you is if the axles in the lifters aren't perfectly centered. that will change lobe centerline and valve timing events. I've seen that one drive some top tier engine builders crazy trying to find that 40 hp gremlin.
So Comp admitted that the cam should not have been let out the door and had me send it back to be reground. They also said it would be done by their race department to ensure better grind accuracy. After they were done, my Custmer Service rep called me and said they actually ground a new blank because the cam was too far out to get correct. The accuracy of all the specs are noticably better in that deviation is very little compared to the deviation of the first cam. Now the advance isn't spot on 2.0 advance this time either...it is now basically a 2.5 advance. But that falls in my acceptable range and actually works out for the better once the new cam chain stretches a hair.
Comp also gave me a $50 discount on any of their cam and dyno software, so I took advantage and picked up DynoSim Advanced with Protools.
So anyway, here is the old report so you don't have to page back to see it:
Adcole report:
Cyl.....LSA......Advance
1 --- 114.02 --- 3.86
2 --- 114.16 --- 4.31
3 --- 114.07 --- 3.97
4 --- 113.96 --- 3.90
5 --- 114.28 --- 4.09
6 --- 114.23 --- 3.98
7 --- 113.77 --- 4.59
8 --- 113.77 --- 4.46
Intake Lobes:
cyl ------ .020 --- .050 --- .200 ---- lift
Design-- 249.3 -- 222.8 -- 148.9 -- .3750
1 ------- 250.5 -- 223.8 -- 149.4 -- .3752
2 ------- 250.6 -- 223.9 -- 149.4 -- .3745
3 ------- 250.5 -- 223.7 -- 149.2 -- .3742
4 ------- 251.4 -- 224.4 -- 149.6 -- .3751
5 ------- 251.5 -- 224.4 -- 149.4 -- .3747
6 ------- 251.5 -- 224.4 -- 149.4 -- .3746
7 ------- 251.0 -- 224.1 -- 149.5 -- .3747
8 ------- 251.0 -- 224.1 -- 149.5 -- .3750
Exhaust Lobes:
Design-- 253.3 -- 226.8 -- 152.6 -- .3770
1 ------- 254.2 -- 227.6 -- 152.9 -- .3758
2 ------- 254.0 -- 227.5 -- 152.9 -- .3759
3 ------- 254.6 -- 227.7 -- 152.8 -- .3757
4 ------- 254.7 -- 227.8 -- 152.9 -- .3760
5 ------- 254.3 -- 227.7 -- 152.9 -- .3758
6 ------- 254.1 -- 227.5 -- 152.8 -- .3755
7 ------- 254.4 -- 227.7 -- 152.9 -- .3761
8 ------- 254.3 -- 227.5 -- 152.6 -- .3758
Here is the new report:
Adcole report:
1 --- 114.00 --- 2.45
2 --- 114.01 --- 2.46
3 --- 113.99 --- 2.48
4 --- 113.99 --- 2.49
5 --- 114.00 --- 2.47
6 --- 113.98 --- 2.48
7 --- 114.01 --- 2.50
8 --- 114.01 --- 2.51.
Intake Lobes:
1 ------- 250.7 -- 224.3 -- 150.3 -- .3751
2 ------- 250.6 -- 224.1 -- 150.2 -- .3749
3 ------- 250.7 -- 224.2 -- 150.2 -- .3749
4 ------- 250.7 -- 224.2 -- 150.2 -- .3749
5 ------- 250.6 -- 224.2 -- 150.1 -- .3749
6 ------- 250.3 -- 224.0 -- 150.0 -- .3740
7 ------- 250.2 -- 223.9 -- 150.0 -- .3749
8 ------- 249.9 -- 223.7 -- 150.0 -- .3748
Exhaust Lobes:
1 ------- 254.5 -- 228.1 -- 153.8 -- .3769
2 ------- 254.5 -- 228.2 -- 153.9 -- .3769
3 ------- 254.7 -- 228.2 -- 153.8 -- .3769
4 ------- 254.6 -- 228.2 -- 153.8 -- .3769
5 ------- 254.4 -- 228.1 -- 153.8 -- .3769
6 ------- 254.6 -- 228.2 -- 153.8 -- .3769
7 ------- 254.1 -- 227.9 -- 153.7 -- .3770
8 ------- 254.1 -- 227.9 -- 153.7 -- .3769
Any comments?
Hammer
This is the problem when you give a kid a machinists ruler to measure or a blind man a microscope. Some people are shown the way to over analyze (No offense to the original poster)
This has nothing to do with lunching #7. A 1% variance in numbers isnt goingg to make or break a ringland. Lean and mean is what does it.
No one here knows the exact DCR limit accurately enough for any given fuel it will likely be run on for any of that .5% cam innacuracy to honestly matter anyway. 5000 miles down the road and 1 mm3 of carbon buildup and it might detonate into oblivion!
Dont build your motors so close to the edge that you have no margin if your seriously worried about it. There is little to nothing to be gained as far as hp differences between 8.5:1 DCR and 8.8:1 DCR that the average chassis can make use of so why bother? If your going to be that exacting, then you should have an adjustable timing chain and degree your cam in ANYWAY, you think GM gave two ***** about your DCR measurement and your stock sprocket is dead nuts on with its stretch stock chain?
Put an adjustable set on it degree it and be happy. If you got a cam to spec 110% and put it on with your stock chain itll still be off a degree or two
Glad to see Comp got one back to you as accurate as your happy with. Id like to do some back to back testing with a cam like yours first and one as close as possible. Id think 1% power is the most you could find
254/268 .659 .659 114+0
I 254 @ .50
255.2
254.8
254.9
254.9
254.9
254.7
254.9
255.1
E 268 @ .50
267.7
267.6
267.9
267.9
267.7
268.4
267.8
268
Advance 114+0
113.83
113.89
113.89
113.81
113.82
113.76
113.81
113.81
Mine is well within Comps 2' margin for error.
Im in a similar boat recently ordered a grind on a 108/107(lca/ICL) and got a 109/105; the lobes/duration are about perfect its just the ICL has gotten worrysome.
From now on Ive learned to provide some leeway and save me from myself.
The LSA/ ICL is a by-product of VEs
At least this has been my experience. Perhaps I just get lucky?? I have no idea how they actualy input the grind parameters and specs in the grinder.
