texas speed and preformance
i had a 99 ss one time and i had ed wright delete the o2 sensors, it would not pass obdII because it could not read it.
There are several how to's on flycutting if you use the search button. But then again $4k to do all the machine work, labor and have your end result be a fairly stout 383 is a damn good deal.
If you have the money I would take your friend up on his offer. Do it right the first time and call it a day. Just make sure he installs ARP rod bolts and ARP head studs.
yeah, it was back in the early years when i had my first ls1 done, i thought i had a nasty setup with the 216/220 114 cam, and heads.... LOL.... so if i completely block everything then i can get away passing the obdII test??
thanx!
mike
http://picasaweb.google.com/GuitsBoy/LS1EnginePics
No need to remove. Its a LOT of trouble for something so simple.
