Crank bolt tightness importance
Old Mar 27, 2002 | 07:34 PM
LS1derfull's Avatar
Default Crank bolt tightness importance
Since crankshaft is not keyed for oil pump and balancer, it is very important balancer be installed all the way against oil pump. Its this pressure from balancer that forces oil pump to turn with crank shaft, so torque of 240 ft, lbs on used bolt is very critical or you could lose oil pressure! Just a heads up. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 27, 2002 | 07:55 PM
Scalpel's Avatar
Default Re: Crank bolt tightness importance
Thanks for the heads up but don't you use a new crank bolt since these are TTY bolts? Thanks.
y2khawk's Avatar
the oil pump drive/crank sprocket for the timing chain is one in the same piece. It is indeed keyed to the crank.
But, yes the torque on the bolt is important. The bolt keeps the damper spinning w/ the crank for the accesory drive
<small>[ March 27, 2002, 07:55 PM: Message edited by: y2khawk ]</small>
Old Mar 27, 2002 | 08:18 PM
BADZ's Avatar
Moderator
If you do happen to use the old one, you better use some lock tight..
Otherwise spend 5.00 on a new one
Old Mar 27, 2002 | 08:21 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by y2khawk:
<strong>the oil pump drive/crank sprocket for the timing chain is one in the same piece. It is indeed keyed to the crank.
But, yes the torque on the bolt is important. The bolt keeps the damper spinning w/ the crank for the accesory drive</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the correction, i havent been in there yet but i know of other GM motors that use the principal i brought up. NASTY C5, GM does give a torque rating for reusing crank bolt seperately from new bolt torque procedure, so i assume you can go either route.
