??? on timing chain cover
Old Mar 27, 2002 | 11:31 PM
Xsta Z 28's Avatar
Default ??? on timing chain cover
I was noticing today that on Mark's engine that it appears from the factory there was a little bit of white sealant used at the corners where the timing chain cover meets the block and oil pan. Haven't noticed anyone say things about using a little dap of say RTV in the corners. Is this necessary???
BTW we are doing Heads, Cam, Intake and Oil Pump Swap.
TIA
Old Mar 28, 2002 | 10:31 AM
Mark IXZD 150's Avatar
Default Re: ??? on timing chain cover
ttt
Yes, I'd like to know the answer as well. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 28, 2002 | 11:23 AM
TimZ28's Avatar
Yes it is necessary. When you disassemble clean off the old white sealant. When you go to put the front cover back on place a strip of RTV at the corners. You will want to place about a 1/4" wide bead where the cover gasket end and oil pan meet. It will be about half an inch long. The front and back corners are the only places you will ever use RTV on this engine.
Tim
Old Mar 28, 2002 | 01:12 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yup, need that long bead of RTV.
Old Mar 28, 2002 | 03:01 PM
Xsta Z 28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>Yup, need that long bead of RTV.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OK now I am confused, is there just a little gob of RTV in the corners or does the ENTIRE, bottom edge on the timing chain cover need RTV?? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> The factory Oil pan gasket is still there.
Again TIA for all your info. Andy
Old Mar 28, 2002 | 03:12 PM
1madss's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">You will want to place about a 1/4" wide bead where the cover gasket end and oil pan meet. It will be about half an inch long. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In other words just a dab in each corner <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Mark
Old Mar 28, 2002 | 04:24 PM
Xsta Z 28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1madss:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">You will want to place about a 1/4" wide bead where the cover gasket end and oil pan meet. It will be about half an inch long. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In other words just a dab in each corner <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Mark</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oh, DUH, I guess it helps to read the ENTIRE thread! Thanks again. D'oh! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Mar 29, 2002 | 12:05 AM
2000 Camaro SS's Avatar
I did this also. If not it leaks.
Old Mar 29, 2002 | 08:44 AM
Which type (color) of RTV sealant is recommended?
Old Mar 29, 2002 | 04:43 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mark IXZD 150:
<strong>Which type (color) of RTV sealant is recommended?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Almost time... Anyone know?
Old Mar 29, 2002 | 09:02 PM
Bluestreak's Avatar
I used a tube of blue Permatex on mine. I've never had a leak since my cam install... we used a tube of Mopar black RTV that I got for free from a buddy who's a mechanic at a Dodge dealer in the area. No leaks on his SS, either. I don't think it matters.
Old Mar 29, 2002 | 10:04 PM
Jason99T/A's Avatar
I can shift faster than you.
Like they said above, just dab some silicone where the oil pan and front/rear covers meet. I have used both the blue permatex and ultra copper with great luck.
Old Mar 29, 2002 | 10:47 PM
LS1Tech Co-Founder
We used black all the way across.
Old Mar 29, 2002 | 11:04 PM
Xsta Z 28's Avatar
Thanks for all the replies. We used some Felpro black RTV. The cam, timing chain, cover, oil pump, ASP pulley and water pump are back on.
Woo Hoo, moving in the right direction. Tomorrow should finish up, but unfortunately waiting for the TB to come back. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Thanks again, you help is greatly appreciated.
Andy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
