What is the biggest sleeper cam?
TIA,
Jason
Weren't some folks having decent luck with the ZO6 cams?
I have a 226/226 114 on the Comp XE-R lobes and the cam is very hard to detect at 900 - 950 idle.
If you will keep your idle speed down around 650 - 700 then a 212/214 115 will be stealthy.
do you have a high stall converter? an 850 idle on a stock converter would make the car pull at stops.
Seth
That's not to say that everyone should dive right in and start programming thier own PCM's. You could cause a lot of damage if you aren't careful...
Will you need programming? It's hard to say. If you want to keep a stock like idle, it may require raising your idle speed a tad. You may want to raise the rev limiter and change shiftpoints as well. A cam swap usually will change your powerband some, and you'll want to be able to get the most out of it by reprogramming the PCM accordingly.
<small>[ April 01, 2002, 10:16 PM: Message edited by: GeorgeC ]</small>
seth
