What you think about this cam?
Old Jan 26, 2007 | 09:41 PM
  #81
CaMaRo67RS355's Avatar
im pretty decided on the G5X3 however i had the time to call around and i just wanted to see what other shops had to say so far ive talked to WS6 Store, Thunder Racing, LG, Tick Performance - the guy from TR said that the G5X3 is probably too much for the street and he recommended the 230/224 im still open to opinions right now im just looking at what all is out there........
Old Jan 26, 2007 | 11:56 PM
  #82
PREDATOR-Z's Avatar
Well if it is a cam only install, I would have to agree with him TR230/224 on a 111LSA is better suited for the job.
Old Jan 27, 2007 | 01:39 AM
  #83
cam only for now but in a few months heads
Old Jan 27, 2007 | 01:51 AM
  #84
oh yeah the only bad thing bout the TR 230/224 is i gott change my rockers and i kinda wanna wait til i do heads for that...
Old Jan 27, 2007 | 03:18 AM
  #85
PREDATOR-Z's Avatar
Old Jan 27, 2007 | 08:02 AM
  #86
01Z0H6's Avatar
Rockers...??? Why?
Old Jan 27, 2007 | 10:03 AM
  #87
that what the guy told me cause of the lope it makes it tears the stock ones up it even says it on there site...
Old Jan 27, 2007 | 10:22 AM
  #88
N4cer's Avatar
Um, no. I'm on stock rockers and I have way more lope than that cam will.
Old Jan 27, 2007 | 10:47 AM
  #89
PREDATOR-Z's Avatar
Boloni
Old Jan 27, 2007 | 11:14 AM
  #90
thats kind of what i though but im new to this whole cam stuff and didnt know what to think.
Old Jan 28, 2007 | 10:58 AM
  #91
if i go to big of a cam for the street what will it act like and stuff when driving at kinda low rpm's?
Old Jan 28, 2007 | 11:08 AM
  #92
98Z28MASS's Avatar
The only time the car should act up is when your rolling around at low speeds/low rpms without giving th ecar any gas, say in a parking lot. Thats the only time my car would surge a little bit, but it was nothing major and a quick tap of the gas would stop the surging. If your really concerned about driveability then go with the 230/224. Anything in the 230+/230+ ranging is going to have some minor drivability issues, but thats the sacrific you need to make if you want a cam only setup over 400 rwhp. I honestly dont know what to tell you though other than you have to just make a decision and go with it.
Old Jan 28, 2007 | 12:07 PM
  #93
JRracing's Avatar
I had the TR230/224 and it was very streetable. Even for a DD. I also did not replace the rockers. They did not tell me that either. It ran fine. And I was very happy with it. I did the job myself and had never done a cam install.
I just took out a cam that is exactly like the g5x3. 234/242. It would not been real good with every day driving. I also put heads on with it. The low end was like stock but it pulled like a train after 4K rpms.
I was actually happier with the 230/224 for street use.
And re use your stock rockers.
Old Jan 28, 2007 | 01:41 PM
  #94
hammertime's Avatar
I've researched Reverse Split cams a lot, and my findings seem to show great results with stock heads and ls1/ls6 intake manifolds. The problem is, an aftermarket or P&P head with much stronger intake flow seems to prefer a traditional split. Selecting a reverse split now may work against you in the end when you do get your heads on.
Again, it think it is important for you to look at what you want in the end, and build in that direction. If you only make 385 hp cam only, and then 430+ hp when you get your heads on there, you should end up with a very drivable setup that performs well no matter what you ask of it.
If you're dead set on breaking 400 cam only, pony up for the Fast 90 and matching throttle body + underdrive pullies. That intake setup will work well to feed a traditional split, and even better once heads arrive to complete the package.
By Brett Foote | 2026-06-04 05:00:17
