x-er224 or...
Old Apr 2, 2002 | 04:44 PM
BYBYC5's Avatar
*Bad Trader*
Default x-er224 or...
Well im upgrading and was wanting to get an opinon, X-ER 224 or TR224, i got an auto and had a 114ls cam(idle was ok but could be a little more rough) you think either one of those cams on a 112 is gonna cause probs?
Old Apr 2, 2002 | 05:06 PM
TimZ28's Avatar
Default Re: x-er224 or...
Go with the XE-R. It has a bit more lift and can be purchased for less.
Tim
Old Apr 2, 2002 | 05:30 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I bought the 224 XE-R on a 112 LSA, and I'm an auto as well. The ramp rates are virtually identical to the TR224 cam. I wanted the added lift, so I went with the Comp. The GP going on through TR right now is pretty good, so you might try to get in on it.
__________________
Old Apr 3, 2002 | 09:25 AM
Terry Burger's Avatar
Kevin afraid to try a real cam? Be a man, get the MMS 229v2.1 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 3, 2002 | 02:47 PM
geniusjester's Avatar
trevor d: what valvetrain setup did you go with (springs and lifters)? i am still tryin to decide on which cam between the tr224 vs. xe-r 224. do you think there is a noticeable difference between the two?
Old Apr 3, 2002 | 05:14 PM
I ordered the Comp 7.4" pushrods, 918 springs, and 772 titanium retainers w/ the cam. Knock on wood, the 918's have held up thus far, and I hope they continue to. As jfm mentioned, hopefully when they have 10,000 miles on them they won't run into valve float problems. I guess only time will tell.
As for the difference between them, if there is any it won't be much at all. As I said before, the only real difference between the two is in lift. I wanted to try out the added lift. It certainly can't hurt power-wise. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
__________________
Old Apr 3, 2002 | 05:16 PM
BYBYC5's Avatar
*Bad Trader*
Terry what speings are you using? u still got that mms224?
Old Apr 3, 2002 | 05:47 PM
VINCE's Avatar
Shorty Director
Decisions, decisions..
