Hammer cam is in!
Old Apr 2, 2002 | 11:38 PM
mmiller's Avatar
Texas Director
Default Hammer cam is in!
I installed the hammer cam on a 112 LSA, <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> Comp 918 valve springs, and MTI hardened push rods tonite in my '01 Z28 (Still have the stock heads). The whole job took about 7-1/2 hours. After everything was done, I hit the ignition and the car fired up immediately. To get it to idle properly we drilled out the throttle body to 13/64" and bent the TB tab just a little to bring the RPM's up to around 700-750. Who said you couldn't run a 112 LSA cam with no tuning?? The car idles great with absolutely no tuning!!
Took her for a test spin. It pulls real hard and smooth all the way to 6400 RPM. You can really feel the car pull very strong in the upper RPM's. I need LS1 edit to be able to bump the rev limiter up to 6800 RPM and adjust my shift points to 6600 RPM. I have the idle set around 700-750 RPM. So far, no codes.
I am hoping to make it to HRP on Wednesday night if the air is halfway decent to see what kind of ET improvement I have gotten with the hammer cam. I am hoping for some 11.50's or if I'm real lucky some 11.40's.
A big thanks goes out to MTI. Jayson, Jeff, Patrick, and Mike for hooking me up on the cam, Comp 918 springs, and MTI hardened pushrods. You guys are the absolute best, and should be commended for having the best R&D, expertise, customer service, and parts inventory. My hat is off to you guys!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Also a big thanks goes out to Steve350 and Raughammer for helping with the install. A job like that sure makes you appreciate having friends that are willing to help out and give you a hand when a hand is needed! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I'll post the results from HRP if I run tomorrow night.
<img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<img border="0" alt="[Chevrolet]" title="" src="graemlins/camaro.gif" />
<small>[ April 02, 2002, 11:40 PM: Message edited by: mmiller ]</small>
Old Apr 2, 2002 | 11:45 PM
VINCE's Avatar
Shorty Director
Default Re: Hammer cam is in!
Sounds like an awesome setup.. Keep us posted..
Old Apr 3, 2002 | 12:46 AM
mike c.'s Avatar
MAN I AGREE. THE HAMMER CAM IS THE BEST,I PUT IT IN MY 2001 WS6 WITH HEADS,12 BOLT W/3.73'S,PULLEYS
WELL... YOU GET THE POINT.THE HAMMER CAM IS MAD.IT'S A GOOD DAILY DRIVER,IT IDLES GREAT IN MY M6 AND MAN DOES IT PULL REAL HARD TO 6,500.ANYONE NEED A CAM? USE THE HAMMER CAM.
Old Apr 3, 2002 | 05:47 AM
jfm's Avatar
jfm
Good luck with your new set up.
I know what you mean about having some buds to help out.I am a grumpy old guy and it is great having help from young blood,Pete,Jay,Big Mike,Mike M and my son.
I have a few Qs for you,which Hammer cam are you using,566 or 581 lift?
Could you list your mods,stall,ect?
I am getting real close to adding some power and like the C2 cam.TIA,John M.
Old Apr 3, 2002 | 08:04 AM
mmiller's Avatar
Texas Director
John,
The hammer cam I am using is the .566 lift. Good luck with your car. You have some really impressive times. Mods are in the sig. (all times before the cam install).
Old Apr 3, 2002 | 08:21 AM
bigSS's Avatar
I didn't realize that you could get different lifts for the Hammer cam. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 3, 2002 | 08:33 AM
Raughammer's Avatar
D(irecto)r Pepper
Congrats Matt. Your car sure sounded good as 700 RPM. To hear both yours and Steve's Hammer cammed cars idling at the same time was just stereophonic music!
Our maiden voyage to "test" out the cam last night was killer, just wish we could have found a suitable victim would have presented himself during our, *cough*, "testing".
Hammer Cam (C1) Specs 222/222 .566/.566 XE lobes
Hammer2 Cam (C2) Specs 224/224 .581/.581 XE-R lobes
Again, congrats on the "job well done" Matt.
Old Apr 3, 2002 | 09:25 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Good job Matt! That car has come a long way in a short time, are you trying to catch up with years of hard work that we have done on these cars? LOL!
Oh I get it, let your racing buddies do all the experimenting first and set the path, then come from behind and buy an LS1 and take the easy way out. Hahaha! Damn Mustang guys. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
Old Apr 3, 2002 | 09:39 AM
11 Bravo's Avatar
Wow, if you got it to idle that easily in an A4 then I may have to think about a 112 again. I wonder why other A4 guys have such a hard time with that and you didn't?
Old Apr 3, 2002 | 11:10 AM
mmiller's Avatar
Texas Director
He, He, He, Tony. What can I say. I guess you would consider me "smart". I listened to too many of you LS1 guys and everything you guys said made too much sense. So here I am. I am VERY satisfied with having made the decision to go the LS1 route. If I had it to do all over again I wouldn't change a thing. Thanks for all of your help. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
Bravo,
One of the biggest advantages IMO about hammer cam on a 112 LSA is the fact that you have to rev the motor about 200 RPM less than that of a 114 LSA. In the long run, it should buy you some time on your stock short block. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 3, 2002 | 11:13 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Knowing you, I doubt you keep a stock anything in that motor for very long. LOL!
Old Apr 3, 2002 | 02:47 PM
SteveD's Avatar
That has got to be some kind of record for a cam install in a drive way. I think I can change springs in my sleep. Thanks to MTI for the idea on the spring tool. It is amazing how easy it is to do a cam change on these cars. Look out Tony and John, here we come. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> .
Let me know how it does tonight Matt.
Good Luck <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Apr 3, 2002 | 03:17 PM
Raughammer's Avatar
D(irecto)r Pepper
Steve? your not coming? bummer. I really wanted to see how y'all two hammer camed cars did against each other.
I hope you change your mind and decide to come out.
I just swapped back to the LS6 manifold and have been out there grinding on my calipers.
Getting ready, .... the wife and son will be out there. The cameras battery is all charged up.
Good luck everybody!
Campbellini
Old Apr 3, 2002 | 05:20 PM
11 Bravo's Avatar
Is your idle at 700-750 in P or D? If it's in Park, how does it idle when you shift into D? Also, how long do yall think the 918 springs will last with that lift, will it be reliable? I'm considering that cam now and need info.
Old Apr 3, 2002 | 05:31 PM
Toxic Texan's Avatar
Hey John how is the emissions on the C1 and C2 cams? I still need to pass. I might just stick to the B1. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 3, 2002 | 07:11 PM
Loco's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by steve350:
<strong>That has got to be some kind of record for a cam install in a drive way. I think I can change springs in my sleep. Thanks to MTI for the idea on the spring tool. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What tool is this? I'm in the middle of swapping springs and its kickin my ***. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Apr 3, 2002 | 07:26 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Loco:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by steve350:
<strong>That has got to be some kind of record for a cam install in a drive way. I think I can change springs in my sleep. Thanks to MTI for the idea on the spring tool. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What tool is this? I'm in the middle of swapping springs and its kickin my ***. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Loco, i dont know about them but i used screw type on all except a couple which i have a lever style, that hooks into spring next to the one you are changing, worked good but make sure you have piston oon TDC for every cylinder as you do this.
The lever style compressor is available from most auto parts tool suppliers.
Old Apr 4, 2002 | 11:13 PM
BIG PD's Avatar
how can you tell if its on TDC? i changing the spings in my car right now and i'm trying to use an air compressor but its not working the way i want it too. how do you swap the springs without the valves falling into the bores? thanks
Old Apr 5, 2002 | 08:02 AM
mmiller's Avatar
Texas Director
Paul, to get the car at TDC, take off the timing chain cover and align the two timing marks on the cam and crankshaft (cam at 6 o'clock, and crank at 12 o'clock). To air up the cylinder properly to prevent the valves from falling down into the cylinder you need to have a male fitting on the end of the hose the same as a spark plug thread. Screw it into the spark plug hole. Connect the other end to your air hose, and that pressures up the cylinder and keeps the valves from falling into it.
Old Apr 5, 2002 | 01:56 PM
2000SS's Avatar
congrats matt!
i hope the car runs those numbers.good luck
wayne
