02' LS6 cam question
Old Apr 4, 2002 | 04:11 PM
I8COBRA's Avatar
Default 02' LS6 cam question
Do I need to use the 02' LS6 valves with this cam and springs? Or will my 99' LS1 valves work?
Pete <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 4, 2002 | 05:23 PM
SStrokerAce's Avatar
Default Re: 02' LS6 cam question
I got you on the other forum. Stock will NOT work
Stock LS1 Valves and Stock LS6 Springs. The Stock LS1 Valves will work. That's what I mean
<small>[ April 05, 2002, 07:54 PM: Message edited by: SStrokerAce ]</small>
Old Apr 4, 2002 | 05:52 PM
BIGBOS's Avatar
Don't bother with that cam, if you are going to get something, get something that will actually let you feel a power increase... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 4, 2002 | 06:22 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by I8COBRA:
<strong>Do I need to use the 02' LS6 valves with this cam and springs? Or will my 99' LS1 valves work?
Pete <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The stock valves will work, you dont need ls6 valves but you will only be able to spin to stock 6200 limit with Ls1 valves and 2002 valve springs, and you will either have to lengthen pushrods or use lash caps to offset smaller ls6 base circle. I d ont like when people answer you by trying to change your mind.No reply is better than discouraging opinionated answer.
Old Apr 4, 2002 | 06:54 PM
99RedHawk's Avatar
What are the 02 ls6 cam specs and anyone have any part numbers on the longer push rods?
Old Apr 4, 2002 | 07:02 PM
Scalpel's Avatar
Here are the specs:
2002 LS6
204/218 .551/.547 CL:120/115 LSA:117.5 Base Circle: 19.0mm (-0.0276")
I'd be glad to tell you how much longer pushrods are needed but no one can confirm it for me <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Apr 4, 2002 | 07:59 PM
LS1derfull's Avatar
Gentlemen, i just installed Comp custom grind with a 18.75mm base circle and im using stock length Comp #7955 pushrods with no problems.
John Juriga from GM suggested not using this little preload with LS6 cam but lots of us are doing it and its supposed to help prevent hydraulic pump up at hi rpm. just FYI
Old Apr 4, 2002 | 08:04 PM
I8COBRA's Avatar
Thanks guys. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 4, 2002 | 10:24 PM
MyLS1Hauls's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SStrokerAce:
<strong>I got you on the other forum. Stock will NOT work</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry but thats just wrong.
Old Apr 5, 2002 | 08:12 AM
99RedHawk's Avatar
Thanks for the info NastyC5. IF The base circle on the 02`s is 19mm, than what is the base circle on the 01`s? Are you saying there is .0276" difference in cam diameter sizes? I would think that is not enough to need longer push rods or we could jsut install the zo6 push rods ? Right?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Gentlemen, i just installed Comp custom grind with a 18.75mm base circle and im using stock length Comp #7955 pushrods with no problems.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ls1ndefull, you threw me off , when it appears you installed a custom grind that is .25mm smaller than the already smaller 02 zo6 cam diameter? Is that what you are saying and still running LS1 stock lenght push rods?
Brooke
Old Apr 5, 2002 | 09:32 AM
Scalpel's Avatar
The '01 LS1 cam has a base circle ol 19.7 mm
Old Apr 5, 2002 | 06:38 PM
LS1derfull's Avatar
Brooke, i want to simplify this so here we go, cam base circle is actually 39.50mm for stock lS1, I PUT IN A CAM WITH A BASE CIRCLE OF 37.50mm, so its 2mm smaller but lifter only deals with half of circle at a time so 1mm difference which is .039". Now that means i would need pushrod basically .040" longer, i used stock length comp rods and valve train works fine, technically it should rev higher with out fear of lifter pump up with this set up. Hope this helps
Old Apr 5, 2002 | 07:53 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MyLS1Hauls:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SStrokerAce:
<strong>I got you on the other forum. Stock will NOT work</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry but thats just wrong.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I put this on the other forum, I'd like to carry on about this longer since you really want to just respond to my posts.
Old Apr 6, 2002 | 05:15 PM
MyLS1Hauls's Avatar
Huh? I just want people to have the correct information. If any of my info was wrong, I'd hope someone would correct me. Nothing personal man. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 7, 2002 | 02:23 PM
Forget about it.
I was just being misunderstood, it's all good now.
Bret
