rocker arm bolt question
Now about the pushrods, do you run stock valvesprings? If so, you're flirting with disaster. It's easy to float the valves with stock springs, and this causes pushrods to bend in over-rev cases. With hardened pushrods, you're probably going to bend valves instead.
but i appreciate the heads up bud, but is it a problem that they are hardened? other than the over rev thing they should be all right right? but what do you think about the thread cleaner? do you know what the thread is on those bolts though? thanks alot bud i really appreciate it
but i guess i will just have to decide on what i want to do in the future. but thanks alot for the reply bud i really appreciate it, i was under the impression that they used thread locker on the bottom of the bolts. but i might do it just incase. but thanks for all the responses guys.
