Thunder 227/224 .566/.561 114lsa dyno results
#61
The 111 Lobe spread should make more peak tq & power but you'll probably find it might run out of legs earlier. A narrower lobe centre does shorten the power band and they do fall off the power much more aggresively so don't be discouraged. You just might need to get a cam with a little more duration next time. HOWEVER this 111 cam will sound tuff ! GOOD LUCK.
