Whats Stronger?
Old Jan 22, 2007 | 09:28 AM
nastysupaspt's Avatar
Default Whats Stronger?
Whats stronger? Iron block bored out to a 441ci or just using my stock LS1 block
bored out with Darton sleeves to a 454ci. The thing is i want to try and stay away from using a iron block and adding the weight.
What do you guys think?
Old Jan 22, 2007 | 11:03 AM
Also whats the biggest bore you can go on a iron block without sleeves?
Old Jan 22, 2007 | 12:50 PM
SiL3NtXWS6's Avatar
How do you plan to bore to 441ci?
Old Jan 22, 2007 | 01:38 PM
Daez's Avatar
I think 427 is as big as it gets.
Old Jan 22, 2007 | 02:23 PM
z28misfit's Avatar
I would think no matter what the iron block will be stronger.
Old Jan 22, 2007 | 02:25 PM
z28misfit's Avatar
I'm sure the Darton sleeves have their fair share of strength but can't see it being better then the iron block.
Old Jan 22, 2007 | 05:47 PM
JPH's Avatar
JPH
lsx iron block for sure. rated to 2500hp. 4.250 max bore.
Old Jan 22, 2007 | 06:10 PM
MagiC5's Avatar
what block are you planning on boring... and depending on your access to a machine shop i'd think if iyou are going ot go with an iron block.. i'd go with the Lsx block that will be avail. very shortly.
Old Jan 22, 2007 | 07:03 PM
Darton Sleeves's Avatar
Cast iron blocks are made not for their strength but for their low cost to produce.
Ductile iron is much stronger than cast iron.
Cast iron usually has a tensile strength of 30,000 psi to 50,000 psi.
Darton's ductile iron has a tensile strength of 100,000 psi to 150,000 psi.
Old Jan 22, 2007 | 07:18 PM
HeapaShifter's Avatar
Iron is always stronger than aluminum.
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Old Jan 23, 2007 | 01:17 PM
So if an iron block has a tensile strength of 30,000 psi to 50,000 psi and the darton sleeves have a tensile strength of 100,000 psi to 150,000 psi that would make the sleeves stronger. Think about it nascar uses darton sleeves along with top fuel dragsters and i'm not going to be pushing nearly as much power as they do.
Old Jan 23, 2007 | 01:22 PM
Ericbigmac83's Avatar
I believe your only solution is the new LSX block. And whats keeping you from being at "nascar levels" if youre starting with a 44x cube?
Old Jan 23, 2007 | 01:24 PM
Thats what i hear maybe i should just wait and spend a little more for the LSX block. there saying it going to be in the price range of 1800$- 2000$ is that right or a little more?
Old Jan 23, 2007 | 01:33 PM
Cop Car's Avatar
cast iron block over an aluminum one would be roughly a 1% total increase in car weight
Old Jan 23, 2007 | 01:38 PM
so maybe 80lbs heavier then a aluminum block tops?
