GM or ARP Head Bolts?
GM bolts are cheaper for sure, but if you ever swap anything more than once you might as well have spent the $ on the ARP's as they are TTY style and cannot be reused once stretched
They will pay for themselves
Not only are they reuseable, but they also keep you from having to clean the bolt holes again if you ever change to another set of heads.
Food for thought....
i removed my motor out the bottom and it was fairly easy. i am however going to attempt a head swap in car becuase i already have ARP head studs
the reason why the GM bolts are degreed is becuase its much more acurate than torquing. not becuase they are "TTY"
http://www.canadiandriver.com/articles/jk/040303.htm
http://www.xmission.com/~kd7olf/torque.html
http://www.robbos.com.au/myweb/Tech_Bolts.htm
Torque to yield is the method of tightening a fastener so that a high preload is achieved by tightening up the yield point of the fastener material. To do this consistently requires special equipment that monitors the tightening process. Basically, as the tightening is being completed the equipment monitors the torque verses angle of rotation of the fastener. When it deviates from a specified gradient by a certain amount the tool stops the tightening process. The deviation from a specified gradient indicates that the fastener material as yielded.
The torque to yield method is sometimes called yield controlled tightening or joint controlled tightening.
