i need help...
Old Jan 22, 2007 | 01:15 PM
silverbandit0996's Avatar
Default i need help...
i don't have a clue as to what cam to get. i know i am going to get 243's and i would preferably want a cam with a 112 or lower LSA with XE lobes for spring life. i drive my car everyday and its the only car i have, but i want about 400-425 rwhp. do i have any options or am i gonna have to change plans?
Old Jan 22, 2007 | 01:16 PM
brad8266's Avatar
232/236 XE might work well. I would go with the XE-R lobes instead though. The 228/232 cam seems to be getting popular too.
Old Jan 22, 2007 | 01:26 PM
i was weary of running XE-R's cause i hear its a biotch changing valve springs and i know the R's have a pretty aggressive ramp rate.
Old Jan 22, 2007 | 01:27 PM
Patrick G's Avatar
LS1 Tech Administrator
Nothing wrong with XE lobes...they're still fairly high in lift. The main thing you want to concentrate on in achieving your goals with a daily driver is to keep compression high, quench tight and overlap at a moderate level. With quench in the .035" range, you can run static compression above 11.0:1 and hit your hp/tq goals with a smaller cam.
Spend the extra cash on the upgraded springs, upgraded valve job and on head milling. Run a cam in the 224-232 range and you'll hit your goals. You can save your money for a FAST 90/90 when you're ready to step it up in the future.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 22, 2007 | 01:29 PM
do you think i should maybe run the 5.3 heads instead of the ls6's?
Old Jan 22, 2007 | 01:32 PM
Patrick G's Avatar
All consistent evidence on this board shows the 243 heads out-powering the 5.3 heads (if the compression is equal).
__________________
Old Jan 22, 2007 | 01:42 PM
i guess the 243 should be shaved? how much from stock height?
Old Jan 22, 2007 | 01:46 PM
like around 59cc or so?
Old Jan 22, 2007 | 02:05 PM
Patrick G's Avatar
61cc for pistons with no flycuts, 59cc if you're running fly-cut pistons (which will net you around 61cc).
__________________
Old Jan 22, 2007 | 02:41 PM
oh ok thanks for the help.
