Throttle Blade drilling to accomodate Hot Cam
Old Apr 12, 2002 | 09:40 AM
ASR OFF's Avatar
Default Throttle Blade drilling to accomodate Hot Cam
Pardon my ignorance, but could someone explain the who, what and why's for drilling the throttle blade after a Hot Cam install. Thanks.
Old Apr 12, 2002 | 10:51 AM
JC's Avatar
JC
Default Re: Throttle Blade drilling to accomodate Hot Cam
Your car will barely want to idle after the install with the small stock hole. I had to use a freaking 1/4 bit to get mine perfect.
That cam likes big holes. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> LOL
Old Apr 12, 2002 | 10:56 AM
WFO_SS's Avatar
do it to get your IAC counts down to normal. the pcm opens the IAC a lot further to keep the motor running @ idle if you don't drill the TB (helps idle surging.) so, get your car @ operating temps, check your IAC counts& adjust until they're about 30-35 counts. car will idle much better & less surging.
Old Apr 12, 2002 | 01:19 PM
mgreen's Avatar
IAC= Idle Air Control
My 6spd '98 needed NOTHING done for it to idle.
Can't say about the other year manual cars. . .
But the manuals are less likely to need the TB blade drilled than the A4.
Mike
Old Apr 12, 2002 | 01:34 PM
35th SS's Avatar
same here on my 98z.did not need to make hole bigger.its different on every car.hole is still stock.idling@950rpm with setup.
Old Apr 12, 2002 | 01:35 PM
35th SS's Avatar
Old Apr 12, 2002 | 01:40 PM
Fulton 1's Avatar
After the installation, I would recommend monitoring the IAC counts using Autotap. If they're high then you can enlarge the throttle body hole in 1/64" or 1/32" dia. increments (good idea to do a PCM reset too). Then drive it a bit and see where the IAC's settle. Repeat this procedure until you get an acceptable idle.
I ended up having to enlarge mine to 15/64" (2000SS) and I idle right around 800-825rpm without AC on.
<small>[ April 12, 2002, 01:44 PM: Message edited by: Fulton 1 ]</small>
Old Apr 13, 2002 | 12:06 AM
ASR OFF's Avatar
O.K., I am trying to follow this. What does IAC stand for. A scan tool such as autotap can read these numbers?
