Will the B1 Cam Idle Without Computer Tuning?
Old Apr 14, 2002 | 10:47 AM
HorsePower Junkie's Avatar
Default Will the B1 Cam Idle Without Computer Tuning?
Thanks. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ April 14, 2002, 10:49 AM: Message edited by: HorsePower Junkie ]</small>
Old Apr 14, 2002 | 10:48 AM
Default Re: Will the B1 Cam Idle Without Computer Tuning?
...will TB drilling work if it needs a tad more idle?
Old Apr 14, 2002 | 01:18 PM
Will it Idle Ok on an A4 car?
Old Apr 14, 2002 | 03:32 PM
BIG PD's Avatar
with a T1, even with tuning mine didn't idle at all! i had to drill out the tb hole so enough air was getting into the engine even at idle.
Old Apr 14, 2002 | 04:12 PM
NHRATA01's Avatar
I think a B1 should idle ok without tuning, its not quite as lope as a T1.
Hey M6 T1 guys, can you give me some help? With my new T1 in there, the car has a hard time finding idle at startup. I have to hit the gas a little and hold the revs at 1000 for a few seconds, to help it kind of find the idle. If I don't it will die (especially on cold start) or it will surge between 500-1300 for a few seconds until it settles in at 800. Once it settles at 800, there's no problems. Just at any startup. I haven't done any TB drilling, will this cure the problem?
<small>[ April 14, 2002, 04:14 PM: Message edited by: NHRATA01 ]</small>
Old Apr 14, 2002 | 04:52 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by HorsePower Junkie:
<strong>Will it Idle Ok on an A4 car?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You'll need to raise the idle a little, but it won't be a big deal. Just be sure that you have an HPP3 to raise your limiter and shift points. I have the Comp XE-R 224/224, .581"/.581", 112 LSA in my A4, and it's working great with Ed Wright's tuning. I have the idle in gear right at 775-800, and it sounds great with no streetability problems at all.
__________________
Old Apr 15, 2002 | 12:18 AM
swtvictory's Avatar
of course it will.
I am running a T1 with no tuning on an M6,
You might just have to drill out the throttle body plate hole a little bit.
Old Apr 15, 2002 | 12:46 AM
66ImpalaLT1's Avatar
I have a T1, no tuning, no drilling and no problem.
Eric
Old Apr 15, 2002 | 04:33 PM
Raughammer's Avatar
D(irecto)r Pepper
Will the B1 Cam Idle Without Computer Tuning? You should be fine.
In an A4 car you might have to raise the idle just a bit, via the TB hole or bending the tab.
Good Luck!
p.s., there are lots of B1 user, cam comments on my cam page.
