please help!!! i think have wrong push rods or new lifter problems
Old Apr 17, 2002 | 02:59 PM
2000SS's Avatar
Default please help!!! i think have wrong push rods or new lifter problems
hey guys,
i just put gtp stage 2 heads on my car.the car has a cam (b1) in it and all the bolt ons.the heads were milled 30thousanths. i also put new lifters in.(comp cam 875-16s)i had in the car before heads were the hardened pushrods from crane which were the same height as the stock ones. the car is making a sound like rockers at idle, but it comes and goes.the push rod im using is a 7350 and the other is a 7400. im was wondering if the pushrod i have in there is wrong and thats why its making that noise!!!please any help or suggestions would be great.
thanks
wayne
<small>[ April 21, 2002, 01:38 PM: Message edited by: 2000SS ]</small>
Old Apr 17, 2002 | 09:17 PM
wizkid's Avatar
Install Director
Default Re: please help!!! i think have wrong push rods or new lifter problems
You are using 7.35's correct?
Do you know the base cirlce on the cam?
I am guessing you need to use 7.400" push rods. I do and I have heads/cam.
My heads were milled 0.030" and my base circle radius is 0.030" less on the hammer cam so I just stuck with the stock lenght. I have a quite setup.
ERic
Old Apr 18, 2002 | 10:29 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You are running 7.350 pushrods? Sounds right to me unless the base circle is different from what I remember.
Old Apr 21, 2002 | 01:30 PM
2000SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>You are running 7.350 pushrods? Sounds right to me unless the base circle is different from what I remember.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ok!
but what about the lifters!the noise comes and goes. i cranked my car up this morning before i left for work around noon,and it didnt do it but when i got on the freeway about 3miles it did it again for about 5 seconds and it goes away. im thinking its the lifters.it also made the noise yesterday when i cranked it up.???????????
thanks wayne
Old Apr 21, 2002 | 01:35 PM
2000SS's Avatar
ttt
Old Apr 21, 2002 | 04:20 PM
MelloYellow's Avatar
Your pushrods sound right. You probably need them a bit shorter actually. NOT longer.
Comp R's are notoriously loud. Your car should sound like a sewing machine now, esp. with the hood up.
Old Apr 21, 2002 | 07:40 PM
steve's Avatar
how is that beast running wayne...
sounds like you have the right pushrod in it.
should make just a bit of noise.
call me some time bud, i gots a questions i need to axe you..
steve frank
Old Apr 22, 2002 | 10:31 AM
2000SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by steve:
<strong>how is that beast running wayne...
steve frank</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">left you a message this morning!!!steve please call me.281-286-5379work
Old Apr 22, 2002 | 10:39 AM
2000SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by wizkid:
<strong>You are using 7.35's correct?
ERic</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i called mti this morning and i have the b1 cam and they told me the base circle is 1.50 and stock is 1.55.
this is diving me crazy!!!!it comes and goes
Old Apr 23, 2002 | 12:27 AM
Raughammer's Avatar
D(irecto)r Pepper
.....bad lifter from Comp. Have you called them yet?
JC
Old Apr 23, 2002 | 12:39 AM
2000SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Raughammer:
<strong>.....bad lifter from Comp. Have you called them yet?
JC</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">im calling them now.
Old Apr 23, 2002 | 10:24 AM
2000SS's Avatar
well i tried changing the push rods last night and the same noise is there, maybe the 875-16 lifters bleed down and make a little noise!!!
i going crazy trying to figure this out!!!
Old Apr 23, 2002 | 09:04 PM
30thta436's Avatar
Put your stock pushrods back in there. and retorque the rocker arms.
Old Apr 23, 2002 | 09:08 PM
truck's Avatar
are they fast bleed lifters? i have installed a set of comp cam's fast bleed lifters in my old truck's engine and they made a hell of a noise at idle. does the noise go away about 1500 to 2000 rpm?
Old Apr 24, 2002 | 12:19 AM
2000SS's Avatar
steve please call me.281-286-5379work when you get this.
thanks wayne
