Possible reasons for popping under acceleration?
Old Apr 22, 2002 | 11:55 PM
xssive's Avatar
Default Possible reasons for popping under acceleration?
I am stumped up to this point. The car just out of the blue sometimes after some harder runs will start popping like crazy out the exhaust. This is not the popping under decel that is common, this is during WOT. It seemed to start right after the macs were put on... Bad plugs? THey are bosch platinums
Old Apr 22, 2002 | 11:57 PM
xssive's Avatar
Old Apr 23, 2002 | 07:38 AM
BIGBOS's Avatar
Default Re: Possible reasons for popping under acceleration?
Could be running a little lean... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 23, 2002 | 07:40 AM
cablebandit's Avatar
my car did that when it was very rich...would even do it while doing a burn out
Old Apr 23, 2002 | 07:59 AM
2000 Camaro SS's Avatar
Mine did that at the track once. As it turned out a piece of aluminum flashing came off of the head and was slammed between the valve and the valve seat. This was allowing the backfire to come from the intake. It also bent the valve. (I had to correct mine came from the intake but the same thing can happen on the exhaust side.)
<small>[ April 23, 2002, 08:02 AM: Message edited by: 2000 Camaro SS ]</small>
Old Apr 23, 2002 | 10:49 AM
Red01Z's Avatar
I had a similar problem after I put my SLP lt's on. I found a plug wire was loose.
Old Apr 23, 2002 | 11:04 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How bad is it popping?
Old Apr 23, 2002 | 11:26 AM
fastflames's Avatar
I am having the same problem. At WOT it just pops consecutively. I tried letting off a little and get back on it and it still does it. What's the deal.
Joe <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Apr 23, 2002 | 11:29 AM
fastflames's Avatar
after putting the wire back correctly, did it fix the problem?
Old Apr 23, 2002 | 11:36 AM
xssive's Avatar
The popping it like gunshots. It will do it consecutively like 5-6 times till I let off. Then it will do it againg if I get back on it. It will happen like once a night but it freaks the crap outta me. Clogged injector? Cracked plug?
Old Apr 24, 2002 | 12:36 AM
itSStock's Avatar
Usually, pop through exhaust is rich and pop through the intake is lean. There are many other factors that can come into play also. Have you a-tapped?? Headers will usually richen it up, combined with some border line plugs coulod break up under load....just a thought.
Fireball's Avatar
double post...locking this one <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Apr 24, 2002 | 12:38 AM
LS1Tech Co-Founder
Mine would do that it, and it was my crank sensor. I rewired the CKP from the sensor to the pcm.
