going bigger valves on 243's
different pushrod length? etc....
thanks in advance
I was gonna do 2.02 and 1.56 w/a 224 cam
that should be plenty of clearance right?
Not sure the valvespring would matter because of the vavle size? Lift on cam and rpm would matter.
IF??? They fit the stock opening whats to blend?
Aftermarket valves with a thick margin (like the Manley valves) are going to reduce clearance. You'll notice a large reduction from a manley VS. stock even for the stock 2.00" valve. Increasing the diameter of the valve will only further decrease clearance. I guess it was too expensive to have valve reliefs cut in our pistons when they were being cast since we had 15 degree heads. Hmmmm...
Ben T.
back up question: If you leave the heads stock and just change vavle sizes 2.02/1.57 would it be an improvement or just if you have the heads port and polished-cnc'ed.
I totally agree with the limited gains. With the good results coming in from all the stock valved ls6 heads out there, its hard to justify the cost when budget is a concern.
