Rollmaster Double Roller Timing Chains instructins
Old Jan 25, 2007 | 08:24 PM
camarokid94's Avatar
Default Rollmaster Double Roller Timing Chains instructins
i got one with no instructions and i need to advance 4 degrees . anyone have instructions that i can see or can soemone tell me i need to knwo by sun morning thanks.
Old Jan 25, 2007 | 08:31 PM
Davy_Baby9's Avatar
I used to have mine. If I remember correctly, on the crank sprocket, each key hole represents 2 degrees.
Old Jan 25, 2007 | 08:49 PM
but do i still line the dots on the gears cause that looks extreme
Old Jan 25, 2007 | 09:18 PM
Davy_Baby9's Avatar
Yea, I started dot to dot and it worked out for me that way.
Old Jan 26, 2007 | 10:08 AM
Humm Ill Just Have To Jsut Degree It And Work It Out.....
Old Jan 26, 2007 | 05:19 PM
JPH's Avatar
JPH
use the +4 keyway on the crank socket, but the tdc dot is on the +6 keyway, so make sure the cam dot lines up with the small dot above/offset of the keyway on +6.
Old Jan 27, 2007 | 09:13 PM
see thats whats weird is there is no other dots on the crank gear only o
Old Jan 27, 2007 | 11:45 PM
ArcticZ28's Avatar
Here you go:
http://www.romac.com.au/pdf/Std%20&%...ank%20Info.pdf
By the way, +4 does not mean 4 degrees of advance on the cam, it's way more than that. That's simply how rollmaster represents that mark on the crank gear. Think about it... look how much you're turning the crank gear as compared to how far the cam rotates when you do that. That's a bit more than 4 degrees.
Old Jan 28, 2007 | 12:18 AM
JRracing's Avatar
I put mine DTD. I don't no anything about degreeing a cam.
Old Jan 28, 2007 | 09:50 AM
Originally Posted by ArcticZ28
Here you go:
thanks that does help..... im still gonna degree it to make sure the ICL is at 109 like it should be...
