View Poll Results: Which cam
TSP Magic Stick 4
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
60
33.33%
G5X4
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
27
15.00%
TRex
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
46
25.56%
Other(please include which other cam you think is best)
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
47
26.11%
Voters: 180. You may not vote on this poll
which cam for cam only car?
#61
LOL! usually when somebody beats you, its by a few minutes. The post you referenced was made at least a week prior to you joining the site, and 5 months prior to your response.
#63
Hmmm, usually with a cam that big it's only going to perform at it's max with a set of high flowing heads... at least that's what i've read and seen in dyno results. Granted the TRex has got a pretty sick record for cam only, but i'd prefer to eat my toast with butter ![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
If i were you, i'd broaden your choices a bit. Try something a little smaller like a 228R or a TV2.
#65
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
I have a question regarding this ASA cam from GM. I have a stock LS1 Camaro with SLP long tubes, Cold Air, Ported MAF, Ported TB, Custom PCM Tune, LS6 Manifold, 3" true duals (no cats, mufflers, or rear O2's), 3.73's, and a 2600 stall. I spray it with a TNT Wet 150 HP shot. My times are 11.35 to 11.39 @122 MPH on E/T streets. I am thinking of going with a Cam and the only one that caught my attention in this thread was the ASA by GM.
Is this a good cam with nitrous? Do I need less overlap with the N2O? I want to keep from having to change the springs. Thanks guys. -Tom.
#66
Yes the asa cam will work great with nitrous, many guys I ahve talked to with them on here make it into the 10's with cam only and nitrous. I too am thinking of running taht cam being I already have the LS6 springs installed, the cam sounds killer, and agree with you about the spring 'life'. Yes there are better cams out there but A4 cars have made 350-360rwhp and M6 cars 390+ rwhp. Sounds like a great cam to me and can always upgrade it later if you decide to get some nicely ported heads.
#69
Ok guys, im pretty new to this whole cam thing. I have a 2001 TA WS6 M6 that im looking to go cam only with for the time being. This car isnt my daily driver, its a weekend car, taht will see occasional strip time. Im wanting a cam that is capable of putting me into mid 11's. Right now my car is stock, but will have LT's with Dynomax Bullet Mufflers hung from the collectors, LID, then of course SFC's, TQ Arm, Panhard bar, with a moser 12 bolt, with 3.73 gears. Anyhow, choices are the MS4, G5X4, or TRex
But i will tell you, i have a custom grind of 228/232 .588/.595 110+4... on my CAM ONLY car.. See my dyno numbers in my sig. BTW here are my mods when i dynoed
I honestly wish that i would have went bigger. I also have a idle vid too in my sig
2002 Trans Am M6
Engine
TSP Cam: 228/232 .588/.595 110+4 | MTI Lid | K&N w/Removed Air Silencer | WS6 Lower Air Box | P&P TB | TB Body By-Pass | Bump Stop Mod | 160 T-Stat | ASP Pulley
Exhaust (3" True Duals Under The Axel)
QTP LTs | Custom 3" O/R H Pipe | Flowmaster 1 Chamber Mufflers | GMMG Tips
#70
for a daily driver I would not go with a large cam and definetly not for a first cam. The largest recomended cams for daily driver (and still to large) would be a G5x2 on 112. TSP torquer 2 on 111, TR 230/236 on 112, FMS F-13 on 112
#71
I have heard this line of thought for a while but I also didn't want to go bigger later after I realized I wanted more. I daily drive my Mega Death reverse split 244/242 6.12 on 112lsa and absolutely love it.
#72
I have not heard of the mega death. You are runnning a reverse split because you are leaving the heads stock?
#78
Do you have a print out of you dyno? I have never seen #"s like that with your torque and HP so close together especially cam only with a cam that size. You might be onto something here.
#79
https://ls1tech.com/forums/pontiac-gto-2004-2006/813669-couple-vids-dyno-1-4-mile.html
