? on chamber work on MTI stage II LS6 heads
I just received a set of stage II LS6 heads. I'm far from an expert as to what exactly should be done.
The chambers were not polished. Should they be?
Thanks,
Bill
Thanks,
Bill
Hi Brian,
I was talking about the combustion chamber.
There is some pictures on this post.
link
<small>[ May 04, 2002, 11:14 PM: Message edited by: Bill00Formula ]</small>
link
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Bill00Formula:
<strong>Hi Brian,
I was talking about the place where the 2 valves open into.
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=002421</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There are several schools of thought on this question, polished chambers have less surface area to absorb comb. heat(power) but rougher chamber finish helps combustion process by breaking up fuel as a liquid into burnable droplets when it splashes on finish in chamber. Both have there bonuses to making extra power. It will probably make similar power with unfinished chambers and you dont lose any compression when they are left untouched
<strong>Hi Brian,
Terry there you go again trying to take pot shots @ MTI - just remember Raughammer is only about a 1/2 second faster then you and has you by about 3 mph!!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Yes what do those MTI heads cost? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
They are the standard stg II heads (2.055 and 1.60) and flow 310-315 at 0.650 and 215-220 at 0.650. I bought the heads from Pace Performance and had them shipped to MTI.
Does that sound about right?
I saw Nineball's flowed quit a bit better but he had 2.08" intake valves and they were setup for a bigger cubic inch motor.
Thanks
Thanks
Terry there you go again trying to take pot shots @ MTI - just remember Raughammer is only about a 1/2 second faster then you and has you by about 3 mph!!! Yes what do those MTI heads cost?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">John is quicker/faster for sure, but I doubt its because his heads are working better. What kinda hp/torque does he put down on a dyno?
