Help I need 10rwhp more!
It should run on pump gas at 12.5:1 for at least a run or two. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
OR
You could drive it down to Texas or over here on the east coast for some -DA's <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Actually it might be getting too hot for that. Looks like your SOL! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck
John
Might try putting the head gaskets on the right way instead of backwards
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">They are on OK, that was my '98. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
Terry you got high flo cats or OFF ROAD PIPES? If not let me know!
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Offroad pipes, at the track only of course. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Have you tried the !air filter? I personally wouldn't do it, but I've heard of some people doing that on the dyno.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've tried it on the dyno and at the track. No real gain, but for some reason I tend to launch harder with it out. Maybe !filter lets more cool air in faster for the first 60'?
OK Gang I have a crazy idea:
Change my MMS 229v2.1 out for a 236 camshaft with more lift (and maybe a 112ls?, also notch the pistons to match).
Pull the heads and put in light weight 2.055 size valves (so I can use them with my new larger motor as well).
Open up the intake port, then open up the LS6 intake manifold to match.
Run a thinner head gasket for another 1/2 point of CR.
Put on a MMS ported oil pump, arp rod bolts, and better timing chain while its all apart.
I wonder if all that would be worth another 15-20rwhp? I could see it picking up a lot or not picking up at all.
!upper PHB
!front swaybar brackets
!cruise control module
!rear carpeting piece along the rear part of trunk
!rear catback just run a bullet and turndown clamped
IMO I would try running more timing and 100 octane for some runs as long as it was safe.
Even though you are a pita and remind me of my little cousin Tommy.......
!upper PHB
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Heh. I've already done the upper PHB and front sway bar brackets. I sometimes spend hours at a time looking around for things I'm willing to remove. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> The cruise control is only 4#, so not worth it to me. I'm thinking about the carpet and catback, but thats a seperate issue. I could probably save 70# between the two if I just took them off all together. Despite popular belief I know its a hassle to take the back half carpet out just at the track. Thanks for the ideas though. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>One thing I did but removed was the fernco mod. It looked a bit too ghetto for me. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The Fernco is too ghetto. Ironic coming from you Terry <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
J.
<small>[ May 06, 2002, 10:16 PM: Message edited by: Paul D. ]</small>
Not the easiest thing the world, but it sounds pretty tame compared to what you're already willing to do :-)
also guys, i believe CA has some major sound restrictions at their tracks. which is why terry only dumps one cutout into a race muffler. so dropping the catback would probably be a bit much.
<strong>Lighter driveshaft?Lighter flywheel</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sounds like one of the better ideas here. Should add 10+ hp to the wheels. Do you already these Terry?
'Los
RE: the cam swap, that is what I was thinking. Then I was thinking as long as the heads are off I might as well put in some light weight valves and try to do a bit more port work. Then I was thinking how mad I'd be if I threw a rod and ruined the new valves, so why not ARP rod bolts, a timing chain, and maybe port the oil pump. Then why not try to add more CR? It goes on and on. ... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have an A4 so I can't do much with the flywheel, but my stall is pretty light. I have the stock 2001 alum driveshaft. I have heard the carbon fiber jobs are only 3# lighter?
