Help I need 10rwhp more!
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
The car it was put on, 98TA, was baselined at 382rwhp with H/C/LS6, headers, orp, etc. car went 11.6 last year a number of times with minimal weight reduction.
Just email them at either hotrodizz@aol.com for Tom or lt1larry@aol.com for Larry and mention ask them about Sean's car.
Terry if you weren't such a lame-0 I'd send you the intake that I am supposed to test in a few weeks but I will just test it in a controlled setting.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've always been polite to you John. It's not my fault your car is a turd.
RE the intake, if a sheet metal intake can add 15rwhp over an LS6 intake from 5000-7500rpm, I'd be willing to pay $1800 or so for it. Any idea how much the sheet metal intakes go for? Probably more than my budget I'd imagine?
Is my car a turd? What's wrong with the numbers?
I think the intakes are in that ballpark. I'd check with Tom @ LS1 Speed and go from there. He can tell you what the dyno sheets look like. Be sure to mention to Tom what converter and gear you are running.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll give them a buzz and check them out. Thanks.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's just historically slow for what it has, and the dyno numbers on the new engine are down IMHO.
as i was reading through the posts, you mentioned if it was worth the $1000 to spend on 1 7/8" headers. but what about then selling your TTS's? i'm sure there are people looking to pick up a set of these. if i hadn't just purchased hooker LT's i would have gladly bought them from you. so that brings down the investment quite a bit. and then you'll have those bigger headers for your built motor...just a thought.
Chris
its upto you if you wanna spend a grand for extra 10hp now =)
Do LS1's already have titanium locks and retainers, if not do so, or get some titanium valves, That should free up a few noticable horses.
1) Index the plugs
2) Evans coolant www.evanscoolant.com
3) DRM long tube headers
4) Sheet metal intake. (more top end hp, loss of low rpm torque)
5) Does AFR make a hydrarev kit for the LS1? I know on the LT1 there is some top end hp to be gained by it.
6) Flow match the injectors
7) A dyno has an inertial load of 2800lbs. That means if a car weighs more than that then it might run leaner on the street than on the dyno. Maybe more fuel will help your ET.
1) Index the plugs
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Chris those are some good ideas. Regarding the head porting, I'm doing everything I want to do with the 388 set of heads, only I'm not doing the combustion chamber yet. I'll save that for when the new motor goes in. I really want to see what I can do with more of a max effort 346.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">A couple of people have suggested swapping headers. I'm taking it under consideration, although its hard to justify $1000+ for maybe 5rwhp, you know? My head porting is costing a lot less than that. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If there was something proven I could buy I would. I tried a gutted LS1 intake and lost 20rwhp/20rwtq. If/when someone tries a sheet metal intake and picks up 10rwhp from 6000-7500, I'll be all over it!
www.LS1Speed.com bolted on a sheetmetal intake and picked up from 382rwhp to 416rwhp on a stock CI car with heads and cam. Car already had an LS6 intake. That is with PCM tuning. Car was not pulled over 7000 rpms and the cam in the test car is not a high rpm cam but the peak HP did move up a couple hundred rpms.
If I had more time when MMS was building my 388 I would have ceramic coated the pistons and heads.
A friend of mine broke an MMS valve spring with an MTI T1 cam so I'm probably going to have a set of their springs cryogenicly frozen and then have Swain use their heat dissipation coating on them.
I've heard of greatly reduce BSFC values on V8s that have coated pistons and heads. Hell even GM started coating the skirts on pistons in 2002 LS1s.
http://www.swaintech.com/price.html
Another possibility is to have them low friction coat your ring and pinion. $80.
I would change out the headers. Buddy of mine has 01 SS. 6.0L Heads milled to give 11.25:1 cr. MMS TB, Lid, FRA, 232/226 561/552 112 cam.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Is it a Thunder Racing cam?
Jeremy
