help with cam install....
Old May 8, 2002 | 04:14 PM
2kredCSS's Avatar
Default help with cam install....
Well the person that was going to put my cam is just bailed on me. So it looks like I am going to be doing this myself. Does anyone have a detailed write up on a cam install and is there also anything I should know or look out for? This is my first cam install so I am kinda hesitant. TIA
Old May 8, 2002 | 04:38 PM
Onyx LS1's Avatar
Default Re: help with cam install....
http://www.ls1info.com/cam_install/
http://www.houston-f-body.org/tech/LS1Cam/cam.html
http://www.torquecentral.com/mods/GM...y/cam_install/
http://www.fbodylinks.com/tech/caminstall.htm
http://xs-fx.com/Raughammer/Headscam2/index.htm
<small>[ May 08, 2002, 04:40 PM: Message edited by: Onyx LS1 ]</small>
Old May 8, 2002 | 04:43 PM
2kredCSS's Avatar
I have an asp underdrive pulley installed on my car is that going to make getting the crank pulley off any harder?
Old May 8, 2002 | 04:50 PM
Onyx LS1's Avatar
nope
Old May 8, 2002 | 05:58 PM
2kredCSS's Avatar
How much of a pain is it to change out the valve springs? everyone is saying this is worth paying someone to do it.
Old May 8, 2002 | 06:16 PM
MY99TAWS6's Avatar
They are a pain...allow three days probably for the cam and springs.The springs can be a bitch..
you need the right tool..I used a lyle tool with star turn thing on end and its removable so you can put socket or open end wrench on it for those back springs.I used the longer arm so I could compress my 918 springs a bit more.I didn't use a compressor..just the dot method and it worked fine.Just take your time and you should be ok.Its much better with two people though.
Old May 8, 2002 | 06:22 PM
Mike Hoffpauir's Avatar
I'm not sure what springs MY99TAWS6 is talking about, but Allan at FMS had my comp 26918's on in less than 2 and a half hours. No way should it take three days. The cam swap should take maybe 4-5 hours. Some of the more experienced shops can swap cams in 3 or 4 hours.
Old May 8, 2002 | 07:42 PM
Jason99T/A's Avatar
I can shift faster than you.
The valvesprings are really not hard, assuming you have the correct valvespring compressor. Patience is the key with them. A cam/spring swap should take no longer than one full day, assuming you do not run into any major problems. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 8, 2002 | 08:40 PM
2kredCSS's Avatar
Ok so exactly which compressor am I needing? And also anyone have an idea of how much it might cost?
Old May 8, 2002 | 08:58 PM
SilverGhost's Avatar
Motorboater
you wanna know a real easy way to change springs?
take the heads off and do em on the ground <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 9, 2002 | 05:46 AM
2kredCSS's Avatar
yea but I dont want to pull the heads.... any suggestions on the best spring compressor to use?
Old May 9, 2002 | 05:50 AM
Nickn20's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2kredCSS:
<strong>yea but I dont want to pull the heads.... any suggestions on the best spring compressor to use?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">my buddy got his from sears, it works fine for us, we got a cam install and a oil pump install done on his car in about 8-9 hours, yes we probably do this too much, I actually got sloppy and put the timing cover gasket on backwards though!
