oil pressure
Old Feb 1, 2007 | 10:51 PM
Blk97WS6's Avatar
Originally Posted by SuperSlow02
change the oil and the problem will go away, if you drive the car hard, youll notice it after about 1k miles...but id guess long as it stayed over 40-50, it should be fine. Mine does it too, i just always attributed it to oil getting worn out. I run Mobil 1 extended performance 10-40. Ill try Royal purple and see if that holds up better.
I drive my car pretty hard and ive never had this problem. Not with the stock oil pump, or my ported LS6 pump. and 40psi is not enough oil pressure for WOT runs. But i agree with SuperSlow02 change the oil and see if it stops. might as well try the cheap fixes first.
Old Feb 1, 2007 | 11:39 PM
SuperSlow02's Avatar
the first time i noticed it happening..had me worred but it only does it to me around 2-3k. And after the oil is changed, goes away. Either that or engine is burnin up oil, but not enought to set of the low oil light.
Old Feb 2, 2007 | 04:35 PM
gun5l1ng3r's Avatar
I have had my car do the same even right after oil changes. It only happens between 2000 -3200 RPM. And I always have at least 60 PSI by 6000RPM.
