oil pressure
caugh*punctuation*caugh...
Anyway, from what i got out of that, i have never heard of before. If i were you i wouldnt drive it until you can get it figured out. or at least dont get on it. Sounds like it could be a bad oil pressure sending unit, but it would be giving you problems all the time, bouncing around at idle etc.
Hopefully someone else can chime in and give some info.
if there was a problem with the o-ring he would be losing pressure ALL the time, not just on WOT runs.
what would case that?
My conclusion is that as you go from negative load (engine braking while in gear) to 'regular' load (engine throttle open), there is a slight shift in the rod and main bearings of the crank, causing a slight opening between the crank and the bearings allowing the pressure to drop.
Just my $.02.
Just my $.02.
Still doesnt sound right to me. if that was the problem, i think alot more people would have experienced this and posted about it. and this is the first time ive heard of the problem.
