383 with 59cc heads? SCR/DCR?
Keep current topend, but go with a forged TSP 383 bottom end. What would my DCR/SCR be and would it be optimal?
ETP 215 @ 59cc/Cometic .040
Fast 90(ported)
G5X3/114
This combo will run me about $6,000 after a new clutch and all the incidentals...
Or go with a LS7 setup and put myself somewhere in the $12,000 range?
All thoughts are welcomed and appreciated!
Alan
Fast 90(ported)
G5X3/114
Alan
I could always change the headgaskets. I calculated it out to be like low 13's on the SCR and mid-high 9's on the DCR which are both way up there...
I thought I made an error, so I figured I would make a post and gather some thoughts!
Alan
347 $3k
383 $4,250
402 $5k
427 $12k(full build with new dual disc clutch, minus $ recouped from selling off 346 parts)
Oh, I'm not made of money either, so the realistic side may get the better part of me here....
Alan
no you cant... you have to keep your quench down... those CC"s on the heads are way too small.. go with some 65's minimum
with my 63 CC heads, .010 out of the bore pistons, -8cc dish's and .040 gaskets my compression comes out to 11.83:1.... he has less dish, way smaller head CC's and everything else seems the same?? i cant use my calculator but seems like it will be well over 12:1 compression ration..
correct me if im wrong.. like i said i cant get on my calclulator.. ****** dial up
Are you taking into account that your 408 is a 4.00 bore and a 383 is 3.905?
makes alot more sense now
thanks guys
