Very interesting info about Royal Purple
Old 05-20-2002, 03:51 PM
Patman's Avatar
Default Re: Very interesting info about Royal Purple
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StevieZ:
<strong>Actually RP #41 has a higher than street detergent package that rivals the specs of a diesel oil! It is made for endurance.It also has a higher flash point comparable to other 100% synthetic based oils (which it is also)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What is the TBN (Total Base Number) on that particular oil? It should be at least a 7 or 8 for street use. I'd still be leery of using it though, as a race oil is going to be formulated differently in the other areas as well (different levels of antioxidants, antifoaming agents, etc.) I couldn't find the specs on the RP race oil on their site, do you know where I can find them? I have always been told by a lot of different people that their race oils contain a low amount of detergents, so finding out the TBN of that oil will help me determine if that info is false or not. Because of the other reasons listed above though, I still wouldn't recommend a race oil for street use, especially not for longer oil change intervals (which really is one of the big reasons to go synthetic in the first place)
Old 05-20-2002, 04:16 PM
StevieZ's Avatar
The fellow who first turned me on to RP was an additive formulation engineer for Texaco. He told me the TBN for this oil was 11 . I too could not find the specs on their website but I took his unbiased opinion at face value and have been using it ever since. He was the one who bought my 94 Viper (the 1 before the 98) and guess what he puts in that?? Mobil 1 Delvac. That's right! A diesel oil in a Viper. His opinion is that you get a much better additive package in a diesel oil than in a regular motor oil. He has converted many Viper owners to use of Delvac
Old 05-20-2002, 06:39 PM
Patman's Avatar
A TBN of 11 is very impressive! I guess my sources were wrong about the detergent package on that oil. Like I said though, I'd still be careful because of it's other properties.
I do know about the Delvac oil, it's a little secret oil that nobody knows much about, but it's extremely impressive. It's Mobil's best oil. It's hard to find though, and very very expensive. Most people get it at truck stops, but I have seen it at Walmart up here. It's $36 CDN for a 4 quart jug though, compared to $25 for a 5 quart jug of the regular Mobil 1.
Old 05-20-2002, 06:47 PM
StevieZ's Avatar
I just ordered a new oil that I want to try by AMSOIL It is a 15W40 diesel and marine oil
Check out the specs.
SERVICE LIFE
Diesel engines, fleet vehicle engines and industrial engines: drain oil at intervals up to two times longer than recommended by the engine manufacturer or at six month intervals. Extended drain intervals may be used if they are supported by the findings of used oil analysis.
Personal car and light-truck non-turbocharged gasoline engines and marine craft gasoline engines: drain oil at intervals up to three times longer than those recommended by the engine manufacturer, or one year, whichever comes first.
Non-commercial, turbocharged passenger car gasoline engines: drain oil at intervals up to two times longer than those recommended by the engine manufacturer, or six months, whichever comes first.
High-performance or racing engines: drain oil at intervals determined by the findings of a used oil analysis program.
Motorcycle engines and small four-cycle gasoline engines: use engine manufacturer's oil drain recommendations
TYPICAL TECHNICAL PROPERTIES
AMSOIL Synthetic SAE 15W-40 Heavy-Duty Diesel and Marine Motor Oil (AME)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
15.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
100.2
Viscosity Index (ASTM D-2270)
164
CCS Viscosity @ -20°C, cP (ASTM D 2602)
3600
Pour Point °C (°F) (ASTM D 97)
-44 (-47)
Flash Point °C (°F) (ASTM D 92)
234 (453)
Four Ball Wear Test (ASTM D-4172 B: 40 kg, 75°C, 1200 rpm, 1 hour, Scar in mm)
0.35
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 6.7
High Temperature/High Shear Viscosity cP, 150°C, 1.0 X 106 s.-1, (ASTM D 4683),
>4.1
Total Base Number
>12.0
Old 05-20-2002, 06:58 PM
DRM C5's Avatar
"I've been doing a ton of research into oils lately"
"I have always been told by a lot of different people that their race oils contain a low amount of detergents, so finding out the TBN of that oil will help me determine if that info is false or not"
"guess my sources were wrong"
So much for all your research. Sounds like it's BS from typical sit on your *** at home oil experts. Since you didn't know RP's TBN value, I doubt you know much about any other of its "properties" to be a credible authority. You should stick to being a digital image retoucher.
Old 05-20-2002, 07:01 PM
Patman's Avatar
Just because I didn't know RPs TBN doesn't mean I haven't been doing a lot of research. Forgive me for not knowing every friggen number on every oil ever made buddy! I've probably forgotten more about oil than you know, so just keep your mouth shut. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old 05-20-2002, 07:10 PM
DRM C5's Avatar
"I've been doing a ton of research into oils lately (more than usual)"
You must have a short memory. <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" />
Old 05-20-2002, 07:11 PM
Patman's Avatar
So what the hell is your point? Because I didn't know RP's TBN that means I don't know anything about oil? Get real. Whatever.
Old 05-20-2002, 07:30 PM
TOO Z MAXX's Avatar
DRM C5
Thanks for adding so much helpful info to this post. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Why dont you post something helpful instead of shooting your mouth off.
Old 05-20-2002, 07:36 PM
TexassTA's Avatar
I,for one, thank Patman for bringing up this subject on "oils" .I use Valoline Syntec 10w-30w,but open to switching to a better "street" oil for my 11 sec. ride.
Old 05-20-2002, 08:25 PM
DRM C5's Avatar
My message is a contribution as it points out how someone is proven not to be as well informed as he would lead us to believe, and this posting misleading information.
Old 05-20-2002, 08:29 PM
  #32
StevieZ's Avatar
Anyone who brings "TBN", "additive package" and "anti-shear" to the conversation has a pretty good idea what they are talking about.
<small>[ May 20, 2002, 08:36 PM: Message edited by: StevieZ ]</small>
Old 05-20-2002, 08:31 PM
  #33
Patman's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DRM C5:
<strong>My message is a contribution as it points out how someone is proven not to be as well informed as he would lead us to believe, and this posting misleading information.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I got one number wrong and all of a sudden I'm posting misleading info? Hardly. I stand by the fact that a race oil is not suitable for street use, it does not contain the right additive package.
By the way, why don't you give us your opinions here since you're such a big expert all of a sudden.
<small>[ May 20, 2002, 08:34 PM: Message edited by: Patman ]</small>
Old 05-20-2002, 08:32 PM
  #34
QUASAR's Avatar
Isnt Royal Purple purple? That alone should be the reason to use it, its cool. Especially with clear valve covers. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
j/k <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 05-20-2002, 08:40 PM
  #35
StevieZ's Avatar
It has a purplish tint but is dark and looks like used oil when new! I have used #41 for 3000 mile intervals with great results but I am anxious to try the AMSOIL 15W40 I mentioned. It has great specs.
<small>[ May 20, 2002, 08:43 PM: Message edited by: StevieZ ]</small>
Old 05-20-2002, 08:57 PM
  #36
DRM C5's Avatar
I never claimed to be an expert and I don't shoot my mouth off on a topic in which I'm not knowledgeable. Your own admissions as I pointed to in my first message in this post demonstrates that neither you or your sources are well informed.
Old 05-20-2002, 09:01 PM
  #37
Patman's Avatar
<strong>I never claimed to be an expert and I don't shoot my mouth off on a topic in which I'm not knowledgeable. Your own admissions as I pointed to in my first message in this post demonstrates that neither you or your sources are well informed.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So all of a sudden I know nothing about oil, just because I got one fact wrong? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old 05-20-2002, 09:32 PM
  #38
zombiedude's Avatar
[QUOTE]Originally posted by Fulton 1:
<strong>You guys might find this discussion interesting:
http://listserv.corvettemuseum.com/c...R1NET&P=R65737</strong>[/QUOTE ]
Man. Now that is interesting!!!!!!! Makes me think! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old 05-20-2002, 09:57 PM
  #39
99 Black Bird T/A's Avatar
Received 1,443 Likes on 1,001 Posts
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Freak:
[QB]test RP with the idea of disproving the claim that you pick up power from it.
[QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've heard RP will show a gain on the dyno when fresh but after about 500 to 1000 miles the additive package is depleted enough the car will not show the gain or less of a gain. I've also heard that RP after about 3000 miles won't dyno any better than any other oil.
Dirty oil will dyno less than clean oil, so it's easy to show a gain just by changing oil.
The real test would be to dyno new fresh Mobile 1 5w-30, drain it pour in RP and dyno again. Then 3000 miles later dyno the RP again and see if it showed the same gains at 3000 miles as it did at 0 miles.
Old 05-21-2002, 12:18 AM
  #40
StevieZ's Avatar
Which Royal Purple did they use in the motor?
<small>[ May 20, 2002, 12:19 PM: Message edited by: StevieZ ]</small>
Quick Reply: Very interesting info about Royal Purple
