Anyone out here running 12.0:1 compression???
Old May 22, 2002 | 11:09 AM
Fireball's Avatar
Default Anyone out here running 12.0:1 compression???
Just wondering if you could share your experiences.
Can you get it to run on 93-94 octane (with reduced timing), what cam size are you running (and what engine CID too). I'm thinking of trying some manly compression <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
Thx
Old May 22, 2002 | 11:12 AM
XtraCajunSS's Avatar
Default Re: Anyone out here running 12.0:1 compression???
I have my engine built at 12.68:1... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> We havent started it yet but will in the next few days... Waiting on my radiator from SLP. Details are in the sig, the cam is fairly big. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> I should be able to let you know in the next couple of weeks. SHoot me an email if you are interested in details.
Shane
Old May 22, 2002 | 01:53 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>Brian if you go big on compression make sure you have big valve reliefs <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I know you like to run a big cam too <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We had to cut even bigger reliefs in my pistons than they came with...
Old May 22, 2002 | 02:20 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Shane,
What is the compression on my new motor? If is 12 to 1 tell Fireball the details. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
I will be in town on Friday afternoon. If the Hot Rod is finished lets go to the track on saturday. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks, see ya
Old May 22, 2002 | 02:23 PM
SpeedDemon's Avatar
If your cam is large enough you may be away with it - or specifically if you bleed off enough compression so you are at much lower dynamic at lower rpms - then you can get away with it.
I wouldn't plan on it though - esp. on a car that will be driven on the street. 11.5:1 is the highest I would go, and 11.2:1 would be my target. The extra point may be worth 5rwhp - but is that 5rwhp worth it if it requires race gas?
You will end up faster in the end if you save up some of that race gas money and throw it in the heads (more flow), or lightening up the car.
Good Luck!
Old May 22, 2002 | 04:04 PM
JimmyKash's Avatar
my one friend had a 12.7:1 LT1 motor with NPG coolant in it and it ran pretty good on pump gas around the street....
but he did throw in the good gas at the track
consequently...one bad tank of 93 caused a ringlad to blow though
Old May 22, 2002 | 09:08 PM
Jason99T/A's Avatar
I can shift faster than you.
Coach, your compression came out to 12.1:1 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The motor consists of JE forged pistons, Oliver rods, stock crank, 5.3l GTP stage 2 heads, Thunder 230/227 111lsa cam.
See you this weekend. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I don't know if I'll be able to go racing (tranny blew up). However, I'll be there for some moral support and maybe a few trips down the track (hint, hint... <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> )
Jason
Old May 22, 2002 | 09:11 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jason99T/A:
<strong>Coach, your compression came out to 12.1:1 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The motor consists of JE forged pistons, Oliver rods, stock crank, 5.3l GTP stage 2 heads, Thunder 230/227 111lsa cam.
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I won't be ready to race yet either <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Car is being sanded down as I write this... Yours is being worked on as well. I believe the harnesses went in today and exhaust is tomorrow...
I'll go to see your monster run though... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Shane
Old May 22, 2002 | 09:13 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SpeedDemon:
<strong>If your cam is large enough you may be away with it - or specifically if you bleed off enough compression so you are at much lower dynamic at lower rpms - then you can get away with it.
Good Luck!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The latest dyno tests I've seen show about a 3-4% HP increase for every point in compression.
Shane
<small>[ May 22, 2002, 09:14 PM: Message edited by: XtraCajunSS ]</small>
Old May 22, 2002 | 11:11 PM
JS's Avatar
JS
U can run as much as 12.4CR with 94 if the tuning is setup properly Brian.I wold talk to Julio about it.
I like the combo u r building but after talking to Julio he said it wasnt worth the money and I should build a big bore such as a 382 or 396 and run a hyd. cam.
I dont know if I wanna do that next yr.
I really want a Z06 or a GTS
JS
Old May 23, 2002 | 12:18 AM
CHRISPY's Avatar
Cheers,
Chris
Old May 23, 2002 | 10:33 AM
CHRISPY's Avatar
Brian,
I think for 94 octane and your hot summer temps I would shoot for 52cc or about 11.5:1 as the highest comp.
Make sure your pistons have big valve reliefs and smooth any sharp edges off the pistons as well. With a good tune and big *** cam you should have no trouble making mad power.
With good rods, great assembly, forged pistons and ARP's throughout you could probably rev to 8Krpm with seasonal refreshening of bearings.
Cheers,
Chris
Old May 23, 2002 | 10:39 AM
Fireball's Avatar
<strong>Brian,
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Chris...You already saw my new cam specs...shhh...but its still ok on lift IMO. Due to the constant backorder on rods and whatnot I'm holding off on the forged bottom end for a tad longer as I may step up to a bigger motor next year <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Right now I'm getting new rings, bearings, rodbolts, etc and letting her come flying apart in style.
My question is how far would a set of 5.3 heads have to be milled for 11.5 and 12.0?
Fire ball,
I hope that Jason & Shane helped you with the info on my new motor. I will run race gas at the track. I will run 93 octane for driving to work.(very slow keeping my foot out of it.) My Hot Rod is set up for the track 1st, street 2nd. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Nice to see another Pewter colored f-body that will haul ***. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Dyno and track times coming real soon.(like this weekend) <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
<small>[ May 23, 2002, 01:00 PM: Message edited by: Coach 02 Z28 ]</small>
Old May 23, 2002 | 01:57 PM
Reckless's Avatar
Super Moderator
If you guys are investing so much in your buildups, why don't you buy LS1 Edit? You can pull timing back for pump gas and drive all you want. Then upload the extra timing for the track when your run the "good gas".
Old May 23, 2002 | 02:49 PM
Ragtop 99's Avatar
LS1Edit?
If it is an affordable cool toy, Fireball has it, or has acces to it. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 23, 2002 | 03:36 PM
Fireball's Avatar
I have LS1edit
Old May 23, 2002 | 07:44 PM
The Guy in MY 99TA's Avatar
I had a 468 BBC sporting about 12.5:1 with a .601"(int) .580"(exh) but the timing wasn't advanced much at all and it ran pretty good on 93 octane. Never made it to the track but the SOTP meter read "HOLY ****". <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Josh S.
Old May 23, 2002 | 09:08 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by XtraCajunSS:
<strong>I won't be ready to race yet either <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Car is being sanded down as I write this...
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sure is cool to see paint & metal fly when Joe let me try the sander this evening. Can you say 'valve reliefs in the rear hatch'?
Tim
Old May 23, 2002 | 09:21 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Can you say 'valve reliefs in the rear hatch'?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ROTF!!
Thats funny as h3ll
Josh S.
