Anyone out here running 12.0:1 compression???
Re: Anyone out here running 12.0:1 compression???
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tim98TA:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by XtraCajunSS:
<strong>I won't be ready to race yet either <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Car is being sanded down as I write this...
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sure is cool to see paint & metal fly when Joe let me try the sander this evening. Can you say 'valve reliefs in the rear hatch'?
Tim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's all right, have your fun now... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Hey Brian. I don't know, I think 12.0 might be pushing it if you still intend on driving a lot on the street. You can more then likely get away with it on pump gas, but it may be kind of a dog. First off, as mentioned above, if your cam bleeds off enough pressure, that will greatly help you. But if it doesn't, more then likely it will want to ping. But, as mentioned, with LS1 Edit, you can dial back the timing. However this will make it a bit sluggish while driving it around. If you can find a way to keep it running cooler, that will help also. Two bottles of water wetter, and a 60-75% water to 25-40% coolant mixture works REAL nice...
I personally would stick with low to mid 11 compression myself. I think 11.5 would be the highest I would try, IF I was really interested in the street performance. That way, you will get the benefits of increased compression, but still have a safe margin before detonation.
Plus, another thing is the increased comp. will really help build torque. And with your monster gears, may end up hurting you more then helping. But on the flip side, your gears will also help to keep the load on the engine down, which may help reduce the chance of detonation.
Just remember the rule, bigger isn't always better. Make sure everything works together. Just take a look around at the loud a$$ cars at Cecil next time that are running slow. THey all throw on a big carb, big rear gears, big cam, then they trailer their un streetable race car to the track and run 12s.... Not saying this is where you will end up, but don't get caught up in the "real men run this" thought process...
<small>[ May 24, 2002, 07:53 AM: Message edited by: Jim98TA ]</small>
well i am curently running on 12.08.1 com. on 375ci on the 232/237 561/561 112 well it kicks ***. no problems on 93 octane for me. but when i switch to 105 octane i feel BIG diffrence.
