She's smokin....
Old May 25, 2002 | 01:38 PM
Stu's Avatar
Stu
Default She's smokin....
You guys think I should forgo the leak down test and just go ahead and rering her?
I made a couple of runs last night and it wasnt smokin during the run. After the coastdown and turn on the return road I gave it a little gas and it started huffin blue smoke like I was sprayin for bugs. It went away after a few minutes.
It smokes a little on WOT runs on the street and uses about a quart every 600 miles. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
It doesnt smoke on startup or at idle.
What do you guys think?
Stu
Old May 25, 2002 | 05:20 PM
NastySSoo's Avatar
Default Re: She's smokin....
Stu, Mine does the exact same thing. Quite a few of us do. IMO its not the rings but the PCV situation. If the rings were bad it should smoke all the time. Mine doesnt smoke at start-up or idle, a little under heavy acceleration and pretty bad after high RPMs on decel.Ive seen quite a few manifolds off, and you would be amazed how much oil is under them. Mine really started doing it after my header install. Coincidence? I dont know. Ive heard recently about a LS6 valley cover replacement part some guys are trying. Im gonna see how they make out. My car has never run better, and no evidence of oil on the plugs . I really dont think its the rings. Im doing a H/k dgets even worse after that. I have 47k and use 1 qt of Mobil 1 every 1200 miles. Well get it figured out!!
Paul
Old May 25, 2002 | 08:29 PM
Stu's Avatar
Stu
Thanks Paul. Is there some kinda mod to do to get rid of that?
I think on that note I'll do a compression check first.
Stu
Old May 25, 2002 | 10:08 PM
tigertat's Avatar
My car did the exact same thing after I put headers on. Never had an oil consumption prob. before that and now 1qt every 1500 miles.
Old May 26, 2002 | 03:35 PM
NastySSoo's Avatar
Theres a few different things guys have tried with varying results. Inline filters, catchcans, the NEW pinhole PCV valve. I tried the new PCV valve and it didnt seem to help. Some guys are mounting the NEW pcv valve vertically. I dont remember who, but someone on this site was gonna post pictures and results of the LS6 valley pan mod very soon. Im anxious to see how that works. I wish I knew before I do my H/C package this week, but Ive been waiting so long for my heads, now that their here Im gonna do the install. Back a few pages on the internal mods you should see some oil consumption, and potential remedies.Stay in touch.
Paul
Old May 26, 2002 | 05:41 PM
2kredCSS's Avatar
my is doing the same thing after header/cam install.. It will puff a small amount of blue smoke at a 6k rev.... But I haven't seen any huge oil consumption problems yet.
Old May 26, 2002 | 06:19 PM
Stu's Avatar
Stu
Paul....Dude I didnt do a test but I found #4 cylinder intake pushrod was bent to hell. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I guess thats why I am runnin slower than the other guys with my same mods. It was bent so bad that it was scored fom contact with the head. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
I think while I got it down this far I might as well order a cam <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Later and thanks for all your help, Stu
Old May 27, 2002 | 09:26 AM
Gag_Halfront's Avatar
Heh... I once had a collapsed intake lifter on an old firebird. smoked like a ****.
Intake stroke: pull oil in around gasket
compression stroke: push oil out around gasket
power stroke: pull oil in around gasket
exhaust stroke: dump oil straight into the exhaust
Mosquitos beware!
