ok, broke headbolt off in block....what now...
ok, in my efforts to get the heads off i broke a bolt off in the block. It was the one on the passenger side, front of the head, right underneat the header.....
what the he11 do i do now?
thanks guys..
matt
thanks guys..
matt
D(irecto)r Pepper
Two words... Eazy-out.
Remove the header (if you havent already)
Remove serpentine belt tensioner. (see above)
Remove spark plug.
Get a M-22 Eazy Out.
Drill a hole in the bolt... Insert EaZy out.... remove bolt.
Did the bolt break off far enough down, that you can still remove the head? It should be fairly easy to remove if so...
Remove spark plug.
