Who has put on 6.0 heads
Is there anyone out there who has sucessfully put on 6.0 heads on ther 5.7 ls1? what was involved, gaskets? any problems? bore misalighnment?
What was the compression ratio after?
I am looking to put some on my Turbo trans am real soon as soon as i get everything.
so need help asap.
Or would it be easier to port out my existing heads to 72cc
<small>[ June 04, 2002, 08:16 AM: Message edited by: smokinHawk ]</small>
so need help asap.
Re: Who has put on 6.0 heads
I used the MLS 6.0L gaskets. You'll need new heads bolt or go the ARP stud route.
No problems thus far.
I milled mine 0.030 and with 2.02/1.60 Ferrea valves installed the chamber volume was 63.5 cc.
Since the Ferrea valves don't have as much (or any) dimple on their face as the stockers they helped to reduce chamber volume. Something to keep in mind if you are changing valves and want to keep a large chamber for your boosted set up.
