Just out of curiosity, would a 98 ls1.....
while the cams are diffrent, its tiny diffrences and it doesent matter in the long run.
What?
Most of the gains from the '01/'02 cars are from the LS6 manifold and the improved exhaust manifolds / converters.
FWIW, my '98 LS1 with Mac midlength headers, cut-out, and a lid went 12.52 @ 110+.
Ben T.
However...
The 98's had the 28lb fuel injectors (so did 01-02), slightly larger camshaft(not much but enough to need an EGR), and the shaft on the throttle blade was different allowing it to open to WOT a little quicker than the later years...
I believe this evens them out enough to where most numbers and times are gonna be about the same.
The differences between the 241 heads and the others is so small, that the diff between one car to another is enough to keep from finding any type of consistancy.
The two cams in question, although one may be bigger as in the actual specs of it, perform nearly identically, and as someone already mentioned, it was changed to do away with the EGR that the 98-00 models had.
Injectors....alot of people talk how some years have larger/smaller injectors. Well the fact is if your not running lean, they arent holding you back. A car in stock or bolt-on configuration wont be hindered by the smaller 26 lbers, nor will the cars with the 28s have an advantage.
The LS6 intake.....yes, it's better no doubt, and should be the only real thing to worry about when comparing the 98-00s vs the 01-02s
Ben T.
Hopefully mine will run the same
Ben T.
