how much are my heads worth?
Old Feb 10, 2007 | 01:01 PM
SVThis's Avatar
Default how much are my heads worth?
i have a set of patriot stage 2 heads
heads specs are:
2.02"/1.57"/59cc
they have about 2K miles on em and absolutly nothing is wrong with them
if i sell them fully assem. what would i be able to get outta them...
Also if i sell them as a package with a Comp Cam 231/237 .585/.595 112 cam that put down 440+ RWHP then how much for the package?
The reason i ask is cause im thinkin about goin with a base style LS6 head cause i wanna go with a bigger cam...my current setip sounds/drives great but i want more of the "big" cam sound!
Old Feb 10, 2007 | 01:15 PM
TheLS1Kid's Avatar
i have those same exact heads with a bigger cam. just flycut the pistons. then you can go as big as you want.
Old Feb 10, 2007 | 01:17 PM
01LS6SS's Avatar
I'll give you $100.
Old Feb 10, 2007 | 03:02 PM
7w/aswap's Avatar
Originally Posted by 01LS6SS
I'll give you $100.
I'll up his bet. Just PM me if you are seriously sellin.
Old Feb 10, 2007 | 03:10 PM
redtail2426's Avatar
yeah why wouldnt you just flycut the pistons,its easy and you can keep your compression up.
Old Feb 10, 2007 | 11:07 PM
SVThis's Avatar
i dont have a flycuttin tool and wouldn't know how to use it is i had one...secondly i dont wanna pay out the *** for someone else to do it...
Old Feb 11, 2007 | 08:14 AM
davered00ss's Avatar
Moderator
Used cam $200-$250
What heads are they 5.3's, LS6 style, LS6 243 castings?
What are they milled? 59cc is a small chamber if they are ls6's.
Used patriot heads have been showing up on the boards for $500-$600 lately.
TSP was even selling some NEW LS6 CNC'd heads for $800 about a month ago.
Old Feb 11, 2007 | 08:56 AM
PREDATOR-Z's Avatar
Just lower your idle and get a true dual dumped before axles.
There is your big cam sound.
Changing your setup just for sound is
Old Feb 11, 2007 | 11:10 AM
SVThis's Avatar
my idle is set at about 550 already...it lopes pretty hard and i got a cut-out right befor the axle...would a true dual setup still be louder than a open cutout at the axle?
Old Feb 11, 2007 | 11:29 AM
PREDATOR-Z's Avatar
No, but it will make better power.
Old Feb 11, 2007 | 11:40 AM
SS4Matt's Avatar
i just sold my patriot stage 2 heads yesterday to a guy named mike here. mine were with the 2.055/1.60 valves and i put Ferrera valves on the intake side. i sold them for $700. mine had about as much use as yours.
Old Feb 11, 2007 | 11:43 AM
SVThis's Avatar
well i know a guy sellin his TSP TD set-up here locally so ill have to give him a hollar...
Old Feb 11, 2007 | 04:36 PM
LS1IMPULSE's Avatar
I have a T-rex comming out of my car in not too long, I trade ya for the heads
Old Feb 11, 2007 | 04:46 PM
SVThis's Avatar
im sure u would
