So who's Blown an engine?
Old Jun 16, 2002 | 02:40 PM
nysbadmk8's Avatar
Default So who's Blown an engine?
overheating took out my block <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> ... how about you guys?
Old Jun 16, 2002 | 06:45 PM
ShiznityZ28's Avatar
Default Re: So who's Blown an engine?
hydrolocked. mine
Old Jun 16, 2002 | 07:11 PM
NBM LS1 M6's Avatar
Bent pushrods. . . when I first owned the car four years ago. Crate engine, clutch, flywheel, pressure plate, and rear pinion seal all replaced under warranty knock on wood. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Jun 16, 2002 | 07:23 PM
VINCE's Avatar
Shorty Director
Appeared to be detonation that killed my pistons. My rocker arms were hitting my retainers and the only thing we could come up with was the valves got hung open in the process and took out several pistons secondary to detonation. I had to replace 8 intake valves because they were tweaked from hitting the pistons and I had a balanced and blue printed forged 346ci shortblock built with valve reliefs this time around.
Old Jun 16, 2002 | 07:27 PM
MIGHTYMOUSE's Avatar
broke a piston in the oringinal one, broke a couple of rods in the one from more perf.. and looks like a few spun bearings/headgaskets in the one from are.
Old Jun 16, 2002 | 08:08 PM
MelloYellow's Avatar
Damn MM! Is that a record?
Oil Pump failure, spun a bearing, threw rod thru the block.
Old Jun 16, 2002 | 11:41 PM
ExtremeZ28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MelloYellow:
<strong>Damn MM! Is that a record?
Oil Pump failure, spun a bearing, threw rod thru the block.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yeah lol David has had the worst luck with motors i sware! But ARE is treating him well he's got a new motor that should be soon and hopefully 4th times a charm <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ June 16, 2002, 11:42 PM: Message edited by: ExtremeZ28 ]</small>
Old Jun 17, 2002 | 01:11 AM
Kevin's Avatar
Snapped a timing chain and bent most of the valves and some nice dents in the pistons.
Kevin
Old Jun 17, 2002 | 02:10 AM
flynbludream's Avatar
I ran over a bird once.
Old Jun 17, 2002 | 09:58 AM
JC's Avatar
JC
oil pump turned evil and threw a rod out the side of the block! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jun 18, 2002 | 12:05 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
First motor was H,c + nitrous, I spun a bearing a few months after putting it together.
Second motor was Westech, and it had issues and broke a timing chain not sure why.
Old Jun 18, 2002 | 12:10 AM
Ragtop 99's Avatar
S/C detonation took out #7 cylinder.
Old Jun 18, 2002 | 12:41 AM
Visceral's Avatar
Pretty sure it started from a rod bolt letting go. Within a fraction of a second, the whole rotating assembly ate itself and left through various holes in the block :-/
Another theory was that a piston disintegrated for one reason or another and caused the mayhem. Im not sure, since all I have are crumbs of aluminum :-/
Saving my pennies for a MTI 393 all bore.
Chris
Old Jun 23, 2002 | 07:38 PM
2000WhiteTA's Avatar
Hydrolocked my engine
