How about this cam setup?
Old Jun 17, 2002 | 11:47 AM
Dustin98SS's Avatar
Default How about this cam setup?
Comp Cams 224/224/ 581 112 with 26918 springs, stock retainers and chromoly pushrods? Will this setup work ok and not break anything? Will I need to change my timing chain or will it work with the stock chain? I'm trying to swap as cheap as possible.
Old Jun 17, 2002 | 03:53 PM
AlonzoVersion 1.0's Avatar
Default Re: How about this cam setup?
Good setup and change your timing chain and also change your oil pump.Katech sales them for 110.It is cheap insurance.They are on ls1.com
Old Jun 17, 2002 | 09:17 PM
SSINFUL's Avatar
I'd swap it out. For several reasons. Every cam creates different harmonics in the associated hardware. The stock chain is sloppy, sloppy enough it *can* retard timing. The Rollmaster double-roller is cheap insurance...
Whatever you do, make damn sure you have a harmonic balancer on yer crank (not just a pulley)!
Old Jun 18, 2002 | 12:11 AM
JurisAg02's Avatar
sounds like a stout setup, I dont see why they wouldn't work..........my 918's take the abuse from a 591/591 226/226 112 cam, no problems here....on the timing chain issue if you are in there I would change it but if you want to keep it cheap and you have low milage on the chain you can leave it in there. Goodluck
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
