What is the ultimate H/C pakage for an A4
And should i spray a 100 shot on the H/C and go with say a ST3500 converter or go just H/C with a TP4400 converter?
Any help would be greatly appreciated
All of this is totally subjective. There are quite a few setups out there making great power, and it's being done with a variety of camshafts. You just need to decide on how much you're willing to tolerate, especially if it's your daily driver!
<small>[ June 20, 2002, 05:46 AM: Message edited by: Trevor D ]</small>
[QBI have a 302 Mercury Mountaineer with a solid roller that makes its power under 6K. The grind (duration and lift) are the specifications that decide streetability, not that a grind is solid or hydraulic. A solid has great benefits because there is no loss of net lift at high RPM like one sees with a hydraulic.
SC[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, I understand that the specs define streetability. A SR setup is actually more streetable over a hydraulic setup with the same duration. My point is that if you're looking for max power you're not going to go with a tame SR cam...at least I wouldn't. If I'm going to go SR, I'm going to make it worth my while. Sticking in a really small SR (such as 229/229 @ .050") isn't worth the added cost IMO. He did say "best 1/4 times possible".
I vote for N/A. A 4L60E trans is on borrowed time with a heads/cam setup as it is; add N2O, and you're going to start trashing trannies before too long.
<strong>A solid roller setup can make some nice power, but you're going to have to really turn the engine to see the benefits. I wouldn't go with a solid-roller setup unless you have a bottom-end that can take those kind of RPM's (over 7k easy).</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am not sure I understand this post. I have a 302 Mercury Mountaineer with a solid roller that makes its power under 6K. The grind (duration and lift) are the specifications that decide streetability, not that a grind is solid or hydraulic. A solid has great benefits because there is no loss of net lift at high RPM like one sees with a hydraulic.
If the solid is ground with a gentle closing ramp, so as not to bounce the valve off the seat, springs can live for 20K or more. Additionally, if the other components are sound you can run it for 10K or more between running the valves.
SC
<small>[ June 20, 2002, 12:56 PM: Message edited by: SS00Blue ]</small>
<strong>i have an FLP Level IV tranny</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would go N/A with a big stall.
