Cam suggestion (patrick G, Predator Help please)
As for street manners, you're asking about all small-medium cams. They'll be fine.
And I believe you'll learn to tune really quickly when you have to. It's not a mystery. You'll just find a similar tune, put it on, then go from there. I'm sure you'll read more and try more once you HAVE to so the car will be right. Should be a great experience. If I wasn't too cheap, I'd buy a wideband and HPTuners or EFILive right now. But I'm too cheap.
0.006 0.050 0.200
Intake Duration - ID 277 227 153 LSK
Exhaust Duration - ED 281 231 156 LSK
Lobe Center Angle - LCA 109 109 109
Intake Centerline - ICL 107 107 107
Intake Valve opens - IVO 31.5 6.5 -30.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 65.5 40.5 3.5 ABDC
Exhaust Valve Opens - EVO 71.5 46.5 9 BBDC
Exhaust Valve Closes - EVC 29.5 4.5 -33 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 111 111 111
Overlap 61 11 -63.5 degrees
0.006 0.050 0.200
Intake Duration - ID 275 226 147 XE-R
Exhaust Duration - ED 279 230 151 XE-R
Lobe Center Angle - LCA 110 110 110
Intake Centerline - ICL 108 108 108
Intake Valve opens - IVO 29.5 5 -34.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 65.5 41 1.5 ABDC
Exhaust Valve Opens - EVO 71.5 47 7.5 BBDC
Exhaust Valve Closes - EVC 27.5 3 -36.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 112 112 112
Overlap 57 8 -71 degrees
Intake Duration: 227 @ .050" LSK Lobe Exhaust Duration: 231 @ .050" LSK Lobe Lobe Center Angle: 109 Intake Centerline: 107 Intake Valve opens: 6.5 Before Top Dead Center (- indicates ATDC) Intake Valve closes: 40.5 After Bottom Dead Center Exhaust Valve Opens: 46.5 Before Bottom Dead Center Exhaust Valve Closes: 4.5 After Top Dead Center (- indicates BTDC) Exhaust Centerline: 111 Overlap 11 degrees Intake Duration: 226 @ .050" XE-R Lobe Exhaust Duration: 230 @ .050" XE-R Lobe Lobe Center Angle: 110 Intake Centerline: 108 Intake Valve opens: 5 Before Top Dead Center (- indicates ATDC) Intake Valve closes: 41 After Bottom Dead Center Exhaust Valve Opens: 47 Before Bottom Dead Center Exhaust Valve Closes: 3 After Top Dead Center (- indicates BTDC) Exhaust Centerline: 112 Overlap 8 degrees
, but ^^^^^^ dosen't make any sense to me. i just don't understand those numbers.
