Cam suggestion (patrick G, Predator Help please)
Old Mar 3, 2007 | 02:19 PM
  #61
1CAMWNDR's Avatar
Hmmm. In the idea of not flycutting for this car, keeping the IVC a little later, etc. How about an LSK 227°/227° 110° LSA +0°. That will give you this:
0.01 0.050 0.200
277 227 153 LSK
277 227 153 LSK
110 110 110
110 110 110
28.5 3.5 -33.5 BTDC (- indicates ATDC)
68.5 43.5 6.5 ABDC
68.5 43.5 6.5 BBDC
28.5 3.5 -33.5 ATDC (- indicates BTDC)
110 110 110
57 7 -67 degrees
Not much overlap, but that would idle easier .
And the overlap is centered.
Old Mar 4, 2007 | 12:37 AM
  #62
silverbandit0996's Avatar
sweet 6200 thats right where i want it. this sounds like the cam for me. what would be a good gear for this cam? also would it be a pain to tune, i think i am gonna have Gomer tune it but just curious.
Old Mar 4, 2007 | 07:03 AM
  #63
Redlinez's Avatar
I made that with the 224/228 581 112+2 Comp XE-R and stock 99 heads with 4.10 gears. You should be able to make 425+ IMHO.
Old Mar 4, 2007 | 07:46 AM
  #64
PREDATOR-Z's Avatar
0.01 0.050 0.200
277 227 153 LSK
277 227 153 LSK
110 110 110
110 110 110
68.5 43.5 6.5 ABDC
68.5 43.5 6.5 BBDC
110 110 110
57 7 -67 degrees
That is a nice no split cam but it would need to be installed with a double roller and degreed to the VEs depicted above. If done dot to dot, I would advance it 2*
That would be like a TSP 228R on steroids
Old Mar 4, 2007 | 09:11 AM
  #65
1CAMWNDR's Avatar
Well, you know a lot more than I do about valve evenets, I am still a novice.
Old Mar 4, 2007 | 03:15 PM
  #66
JimMueller's Avatar
Why do you say this cam would need to be installed with a double roller? How do you determine that from cam specs?
Old Mar 4, 2007 | 07:59 PM
  #67
NoMoreFWD's Avatar
I think he meant to say 'dual valve springs.' That cam needs dual valve springs due to the high lift and aggressive ramps.
Old Mar 4, 2007 | 11:22 PM
  #68
PREDATOR-Z's Avatar
Because:
1- It needs to be adjustable
2- If a cam is left on a +0 advance, then you want as little slack as possible in the chain to keep those VEs, otherwise with slack you end up retarding.
Double roller fits those criterias.
Old Mar 4, 2007 | 11:30 PM
  #69
JimMueller's Avatar
So if the cam had 2* ground in then slack wouldn't be a problem and wouldn't need to be degreed?
Old Mar 5, 2007 | 02:29 AM
  #70
PREDATOR-Z's Avatar
Ideally all cams should be degreed, but but advancing 2* and with slack you'll be close to 0 advance if not degreed (in general)
Old Mar 5, 2007 | 02:55 AM
  #71
BOWTIE's Avatar
This is gonna be a peaky cam as it is exhaust biased from TDC and with 40.5 IVC it will have a early peak around 6000 or so.
I would keep it on a XE-R exhaust lobe, like this:
227/232, .639/.595 110+2 LSA
That looks a lot like mine...
227/234 .639/.598 110+2
Should be here this week with a set of PRC 2.5 5.3's.
Old Mar 5, 2007 | 06:17 PM
  #72
227/232, .639/.595 110+2 LSA will this cam clear stock pistons with a milled 317 head?
Old Mar 5, 2007 | 07:35 PM
  #73
JimMueller's Avatar
And that looks a lot like the cam sitting in my living room along with my 59cc PRC 5.3L heads... 227/235 .644/.650 110+2 ... but I bet you'll have yours installed before I do. I need to spend $1300 on the rear end and $1000 on race tires before mine is going anywhere.
Old Mar 5, 2007 | 10:53 PM
  #74
PREDATOR-Z's Avatar
You are flycutting right?
Old Mar 5, 2007 | 11:03 PM
  #75
N4cer's Avatar
If not, let's hope he's shifting at 2300rpm, if it fits at all.
Old Mar 6, 2007 | 05:40 AM
  #76
JimMueller's Avatar
I've got Wiseco pistons with valve reliefs.
Old Mar 6, 2007 | 07:58 AM
  #77
PREDATOR-Z's Avatar
Cool, just update sig so people do not get the idea you are running this on stock block.
Old Mar 6, 2007 | 08:11 AM
  #78
JimMueller's Avatar
I used to have it in there, but when they began the 500 character signature limit, I had to concatenate
Old Mar 6, 2007 | 09:23 AM
  #79
N4cer's Avatar
LOL you could probably pull the Kumho Ecsta info to put the motor info in.
Old Mar 6, 2007 | 10:12 AM
  #80
1CAMWNDR's Avatar
I'd like to know this also.......
