Whats LSA in a cam spec mean.
Old Jun 21, 2002 | 10:16 AM
hawkls1's Avatar
Default Whats LSA in a cam spec mean.
thank
Old Jun 21, 2002 | 10:20 AM
thxone's Avatar
Default Re: Whats LSA in a cam spec mean.
Lobe Separation Angle
Old Jun 21, 2002 | 10:44 AM
Fireball's Avatar
its the angle between adjacent intake and exhuast lobes...the smaller the angle...the lower the power peak in rpm and the rougher the idle
Old Jun 24, 2002 | 01:14 AM
Fred 02 WS6's Avatar
http://www.newcovenant.com/speedcraf...camshaft/3.htm
Thats part of a good camshaft tech series
Old Jun 25, 2002 | 12:49 AM
The Emperor Of Darkness's Avatar
ok now, is there any relationship between the LSA and bottom/top end?? what exactly is the advantage of having lower LSA?
Thanks
<small>[ June 28, 2002, 08:52 AM: Message edited by: The Emperor Of Darkness ]</small>
Old Jun 26, 2002 | 08:39 PM
Ragtop 99's Avatar
The lower LSA can keep the power band down in a more usable range if you want a big cam but don't want to spin the **** out of your motor or run a 5000 stall converter. Draw backs of a lower LSA include a potentially worse idle and increased emissions.
Old Jun 28, 2002 | 12:53 AM
Slart's Avatar
smaller LSAs generally perform better at low RPM than large LSAs
