Cam setup.
Old Feb 12, 2007 | 06:53 PM
LS1T/A4's Avatar
Default Cam setup.
I am buying an Ed Curits grind cam 224/228 .590/.590 113, these were the specs I was given by the seller. Assuming there is no advance ground in I will end up with a ~7.98 DCR. Is there room for improvement? I would like peak around 6k since I have a 98 car.
Old Apr 20, 2007 | 11:19 PM
LS1T/A4's Avatar
Ttt...
Old Apr 22, 2007 | 02:30 PM
LS1T/A4's Avatar
Anyone?
Old Apr 22, 2007 | 06:59 PM
NoMoreFWD's Avatar
I would be willing to bet there is some advance ground into it, probably between 2 and 4 degrees. Room for improvement? With this cam or another?
Old Apr 22, 2007 | 08:06 PM
LS1T/A4's Avatar
I contacted Cartek, they say its one of their cams and they grind no advance into their cams. I was wondering how much I could advance the cam to get the DCR up.
I think I'm going to send it to Thunder Racing and have them run it through the Cam Doctor so I can see exactly what it is.
Old Apr 22, 2007 | 08:52 PM
DaveX's Avatar
Use a dcr calculator to figure out where it needs to be, and degree it in yourself when you install it. You could also consider shaving your heads a little or using thinner head gaskets to get the dcr up.
