thrust bearing shot ?
Old Feb 13, 2007 | 11:01 PM
oange ss's Avatar
Originally Posted by techx
id say very good... in bizarro world. who knows, you might get lucky... i wouldnt let it go any further. how many miles on it?
well i hope so....just over 40,000, dont know why or what would have caused this...
techx's Avatar
keep in mind that your oil pump is now trying to eat what used to be your thrust bearing in the bottom of the pan.
Old Feb 13, 2007 | 11:02 PM
techx's Avatar
oh i dont know... maybe 6Krpm launches off the line? lol
Old Feb 13, 2007 | 11:03 PM
nofearracing28's Avatar
ah...didnt see that. dunno how long it'll last....maybe someothers will chime in. why not just rebuild it?
Old Feb 13, 2007 | 11:04 PM
oange ss's Avatar
?, have never seen anything bigger than sludge on the drain plug after oil change....i guess some of it might be floating around in there....but i'm bettin it's been a gradual process...still tryin to figure out how/why...any ideas ?
Old Feb 13, 2007 | 11:06 PM
oange ss's Avatar
moving in a few months, have a house to sell, stuff to pack and stuff to do...couldnt have come at a better time.....no reason i couldnt change out the bearings with the motor still in the car is there ? assuming the crank aint screwed....
techx's Avatar
every time you let the clutch out it pushes the crankshaft to the front of the block. sometimes harder than others...
Old Feb 13, 2007 | 11:08 PM
oange ss's Avatar
never had the tires or decent enough track for that, all tho i'm not sayin it's had an easy life....
Old Feb 13, 2007 | 11:09 PM
oange ss's Avatar
good eye...i thought that Ram clutch was a little stiff, but damn...
Old Feb 13, 2007 | 11:14 PM
techx's Avatar
thats a good question. youd be guessing of course on the clearance, unless you used plastigage or something. it would be a bitch but you might be able to do it... retaining your sanity while laying under the car with a tiny screwdriver "picking" at a thrust bearing might be a tall order tho.
could you blame it on GM somehow? 40K miles aint much... hell you should see the stuff toyota is warrantying these days. dont change your oil for 70K miles and we will rebuild it for free!!!
Old Feb 14, 2007 | 10:28 AM
oange ss's Avatar
i've done it before on a regular small block, think i'm just gonna run it till it goes, then get a 347 or 383 if the wife will let me, funny thing is i just bought a 9" last week...just my luck....theres no way none of the worthless dealers around here would touch it,not that i would let em anyway....thanx man
Old Feb 14, 2007 | 12:37 PM
  #32
gun5l1ng3r's Avatar
Then how come there have not been more incidences with these bearings wearing out?
Old Feb 14, 2007 | 05:17 PM
  #33
techx's Avatar
what do you mean exactly by "more incidences". is this the only recorded LSx thrust bearing failure in history? (damn your luck, orange ss! )
Old Feb 14, 2007 | 05:33 PM
  #34
oange ss's Avatar
that's what i'm sayin....
Old Feb 14, 2007 | 06:00 PM
  #35
2 SSlow's Avatar
damn, i would say .035 is very excessive...honesly though, if it were my car, i would drive it until it breaks.. Thats all i can afford to do lol. Seriously, if it drives fine, dont worry about it until if gives you a problem, or untill there is a noticable amount of metal/**** in the oil/on the drain plug. Thats just what i would do, probably not what you should do though...
Old Jan 7, 2009 | 08:54 PM
  #36
OffspringZ28's Avatar
about 2 years later and the car still drives fine...
could this cause this = https://ls1tech.com/forums/generatio...-included.html
Old Jan 14, 2009 | 08:32 AM
  #37
oange ss's Avatar
sounds like a lifter
