What's the torque sequence for the F-Body Oil pan?
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The smaller bolts get 18 lb-ft. These are the ones connecting the oil pan to the block and the oil pan to the front cover. The 2 longer bolts connecting the oil pan to the rear cover get 106 lb-in.
As far the sequence, just run the pan down evenly prior to torqueing the pan. Also, don't forget a little dab of silicon on the four corners where the oil pan meets the front and rear covers.
Jason
<small>[ June 23, 2002, 03:02 PM: Message edited by: Jason99T/A ]</small>
Jason
